  The Mall
  Super Duty 4 NOS Parts Lot
Super Duty 4 NOS Parts Lot by Blowd
Started on: 07-13-2014 08:16 PM
Replies: 3 (459 views)
Last post by: kwagner on 07-15-2014 05:47 PM
Blowd
Report this Post07-13-2014 08:16 PM Click Here to See the Profile for BlowdSend a Private Message to BlowdEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have decided to sell my cache of SD4 parts. Most of it is NOS with some in original boxes. Will only sell as a Lot, you may part out as you wish.
Asking $2995 and I'll pay the shipping to lower 48.
Pics and details are available on ebay listing: http://www.ebay.com/itm/261...id=p3984.m1554.l2649 (auction goes live Sun nite at 8p pacific)
These are the major components and most of the accessories you will need to build a 3.0L engine. You will have to provide your own Pistons, Valvetrain, and Oil Pan to suit your application. Head, Block, and Camshaft are partially machined and will require finishing to your specs. Block is unbored.
These parts have been put away since they were new in the mid 80's. Some rust has developed on the block internals and sheet metal parts. The block was used to display a Cosworth cylinder head kit for some time and was obviously exposed to some humidity. A hardware/Accessory kit is included. A few odds and ends have gone missing over the years. I have bagged, tagged, and provided an inventory of the remainder so you will know what is there.
I am including a few used components: Rods, Valves, Rev Limiter, and Honing Plate, to help complete the engine if you wish to use them.
Basically you are getting: 5-cam bearing Block; 3.625 Crankshaft; -433 Aluminum Head; Accessory Kit (engine hardware, etc.); 4bbl Intake; Valve Cover; Camshaft Blank; Ignition System. See below for more detailed list.
Engine components:
10093315 Block SD Cast Iron 5 cam Bearing
10093312 Crankshaft 3.625" Stroke 3.0L 4130
10045408 B&B Performance Main Cap Studs
10049885 B&B Performance Block Stud Kit
10038433 Aluminum Cylinder Head Bare
299496 Crane Semi Finished Camshaft (blank) 5 cam Brg
xxxxxxxxxx Roller Cam Bearings and retainer plate kit.
110344676864 Edelbrock (2982) 4V Aluminum Intake Manifold
10031327 Aluminum Valve Cover 2pc (o-ring missing)
10037684 Steel Straight Cut Timing Gear Set
10031329 SuperDuty HV Oil Pump w/Pickup Tube
VPR91996STD Vandervell Rod Bearing Set
10031328 Engine Build Pkg (robbed of a few small items sheet metal has some corrosion)
CS2697CE McCord Cork Pan Gasket Set
JV883 Victor Timing Cover Gasket Set
10031324 GM Teflon Coated Wire Ring Head Gasket .038
Accessories:
xxXXX Crane Rev Kit (blue)
XXXXX NOS High Torque sealed starter
84901 MSD Crank Trigger Distributor w/Cap (8575) and Rotor (8459)
82594 MSD Ignition Unit
89801 MSD Timing Computer
8738 MSD Soft Touch Rev control (Used)
82884 MSD Crank Trigger Pickup Bracket
Used (Bonus) Items:
BHJ Honing Torque Plate for Iron Duke (needs 1 hole elongogated for SD4)
6 Manley Pro I-Beam 6.00 Connecting Rods
Ferrea Intake Valves, Coated Hi Flow (undercut stem) 1.94 x 4.935
Ferrea Exhaust Valves, coated 1.60 x 4.91
Blowd
Report this Post07-15-2014 08:11 AM Click Here to See the Profile for BlowdSend a Private Message to BlowdEdit/Delete MessageReply w/QuoteDirect Link to This Post
SOLD! Thanx for the interest and the space!
E.Furgal
Total ratings: 278
Report this Post07-15-2014 01:56 PM Click Here to See the Profile for E.FurgalSend a Private Message to E.FurgalEdit/Delete MessageReply w/QuoteDirect Link to This Post
wow that was fast..
kwagner
Total ratings: 62
Report this Post07-15-2014 05:47 PM Click Here to See the Profile for kwagnerClick Here to visit kwagner's HomePageSend a Private Message to kwagnerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dang, I just saw this and it's already sold! That's what I get for going on vacation
Hope you got what you wanted for it
