Well, unfortunately. I am forced to sell my Fiero because I am now getting a Divorce. Here is my brief build thread.
//www.fiero.nl/forum/Forum1/HTML/093449.htmlI will get more pictures of it after the weekend, I will probably throw it on the lift at the Auto Craft Shop so everyone can see the rot free underside.
Here is a list of parts/mods done to the Formula:
KYB Shocks in the Front
Relocated Battery to the Front
Rebuilt Both Headlight Motors with Rodney's Metal Gears
Mecham Scoops
12" C4 Corvette Rotors (Brand new Zinc Coated, Drilled and Slotted Rotors and Pads)
New Aluminum Brake Master Cylinder
New Rear Brake Lines (the front brake lines are stainless braided lines)
Brand New 17" Konig Lace wheels (Front: 17x7 40mm offset & Rear 17x8 35mm offset) with Brand New Kumho Tires
Momo Millennium Steering Wheel using an NRG Short Hub
Sony Head Unit with JBL 4x6 Plate Speakers in the rear.
Recovered Beechwood Cadillac Shifter Knob
Beechwood Shifter Boots from Russ88ttop
Speedhut Gauge Overlays (I haven't installed the Aux Gauge or AC Control overlays yet, but I have them)
New Adjustable Vacuum Modulator on the 4T60E Transmission
New Gates Barricade Fuel Hoses
New Fuel Filter
Fresh Tune Up and Oil change
New Interstate Battery
Rebuilt and Flowtested 5.0 Ford Fuel Injectors from osidetiger
Camaro Seats (in okay condition)
Parts I haven't installed but have:
Rodney's Lowering Ball Joints
Rear Coil Over setup using KYB Struts
Polyurethane Bushings for the Front Control Arms
Brand New Parking Brake Cables
NOS Front Bumper
Extra set of Notchback tail lights
The Good:It Runs and drives is currently registered and inspected when it doesn't really have to be.
Its a solid Fiero
Its got a great running 4.9L V8 and a nice shifting 4T60E Transmission installed by The Fiero Factory in the early 2000's
Brand new 17" Konig Wheels and Kumho Tires
Many more new parts as well as a small parts stash that will come with the Fiero. (NOS OEM Front Formula Bumper, for example)
The Bad:The paint is baked.
It doesn't have the parking brake hooked up
The Hood has a crack and the corner is chipped off. (But I have an extra hood that goes with it.)
It will need the marker lights replaced because they are baked from the sun. They work though, just ugly.
The gauges don't work properly. I think the Tach was never modified when the swap was done, not sure what the Speedos problem is.
One of the front fenders is cracked, its barely noticeable.
Only one speaker works. The two front ones are factory and blown and the passenger rear speaker doesn't work. Not sure why, but I suspect a bad wire.
This Fiero has alot of stuff done to it, even before I got it.
Make an offer or bid on my auction below.PM me and I can give you my number if you are interested.
[This message has been edited by craigsfiero2007 (edited 07-15-2014).]
