How much for 1 left and 1 right regulator, 2 lock actuators with brackets, and the two crank/lever things that go between the actuators and the lock rods, shipped to 17055?
How about the drivers side spinny roller thing? Pics and price shipped to 11510, granted it's not all messed up like mine.
------------------ ===Always trying to find time to work on cars=== Louis Duet Baldwin, Long Island, NY Where driving hard is SOP. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Blue" <= '85 Fiero GT Stock V6---Stock everything. Trying to keep it 'mostly' that way. ~~~~~~~~~~~~~~~~~~~~~ "Boo" <= '81 Delorean DMC-12 The "DuetLorean" VIN #5835 Stock PRV engine Robertson Equipped Neiland/Delman Engineered Carbed and loving it! (Peugot 604 manifold) ---"Sorry purists"
bottom door hinges YES door actuators YES but dont really know condition of them Spiney thing?? manual window crank shaft that the window crank handle goes on?
I will try to post some pics I have just been really busy I have dashes out of my cars. I had to get power window wiring harness to install into my base coupe
Spinny (not spiny), the roller with the pin in it. I don't know what else its called. Sorry , um there is a metal arm the has a small spring behind it rolls on that and it keeps the door open. I can email you a picture of what I mean if you PM me your email address . Thanks I would need it shipped to 11510. Baldwin , new york
It's called a hinge roller from what I am told. Do you have one in good shape? If so, how much shipped to 11510?
The factory hinge rollers are staked in place, and can't really be removed without damage. Your best bet is either the whole hinge, or one of Rodney's replacements.
Ok, thanks for that info! So then how much for drivers side door hinges? Shipped to 11510 of course. Then replacing the entire hinge will solve my hinge roller and hinge pin issue at the same time. Sweet! They will have to be able to fit my 85 gt door (again-driver's side). I think it's just the bottom hinge that's bad but it may be worth replacing both top and bottom on the driver's side door just to be sure. Thanks ! It would be so nice to have the door open and close without the clunking and squeaking finally! Louis
I have dismantled some doors and have some parts that somebody may need. I want to post them here first before going to the scrap yard.
i could use both dew wipes for both doors, even if they are not in great shape. i need them as template to make some without tearing my doors apart for the duration of the project
