Click here to visit the donation page | View all sponsors
  The Mall
  FS: 1986 Pontiac Fiero GT 3.4DOHC TURBO, CAGED (Page 1)
FS: 1986 Pontiac Fiero GT 3.4DOHC TURBO, CAGED by Coinage
Started on: 11-12-2011 01:23 PM
Replies: 44 (3481 views)
Last post by: Gokart Mozart on 09-26-2012 08:02 AM
Coinage
11-12-2011 01:23 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need to Move this, UPDATED LOWER PRICE 5/29/12
$3000 FIRM!! I need to pay for a wedding!
1986 Pontiac Fiero GT 4 Speed/ 111,xxx miles
I have decided to sell my Fiero, I have owned this one since September of 2005. I have done many things since then but have not driven it much since. I bought this after I wrecked my 85GT and swapped the drivetrain and all the suspension onto this one to make it my driver. Drove it with 2.8 for a few months then started a tear down for initially a turbo 3400 with ported iron heads. Scraped the idea after a while and decided that I would go with a turbo 3.4DOHC instead. I complete the swap in probably in 2009 but I was having clutch issues. I replaced the Quartmaster twin disc clutch setup for a simpler ClutchNet designed for Camaro. This is pretty much the WCF 9 11/16 clutch setup without paying a WCF premium. Since then I haven’t had any drivability issues.
The car is probably around 85-90% done I would say. The main things that would need finished would be, most importantly tuning. I had Darth burn me a starter chip so that it runs/drives. Normal driving is perfect, WOT/ power enrich is where it gets bad, AFR’s drop extremely rich. I haven’t messed with it and I would recommend have it professionally tuned.
It currently has a 3” downpipe that I fabbed up that it can follow the stock exhaust routing. It only has the downpipe, so one would need fabbed up, plenty of room to run a cat and a muffler.
The interior is far from perfect and could use some going over.
Needs a windshield.
Gas gauge is sketchy.
Needs e-cables put in. I modified the stock handle to it can clear the doorbar.
Body is kinda rough but is far from the worst I have seen, probably a 5/10, hood is boogered up and a bunch of other small issues.
With all that said, I am ready to sell. I have moved on and have no reason to keep the car. I am looking to get $5,000 OR BEST OFFER… SERIOUSLY, MAKE ME AN OFFER!
Here is the mod list, most likely missing some things.
Engine:
94 3.4DOHC motor, was a jasper rebuilt when I pulled it. It was rebuilt again before I put it in the Fiero, all new bearings/seals/rings.
ARP Main studs
ARP rod bolts
ARP headstuds
Sealed power Hypereutectic pistons
Reconditioned rods
Balanced bottom end
Ported heads, polished combustion chambers, valve spring shims
96/97 intake manifold
4 speed 3.62 trans
Turbo setup:
Garrett 60-1 Ball bearing .83 T-3 hot side, ported/anti surge compressor housing
Tial 38mm wastegate, has a 14.7psi spring in it
3” in/out air to water intercooler, HUGE heat exchanger up front
52lb/hr injectors, Corvette fuel pump
Suspension/brakes:
KYB shocks/struts, 350# coilover springs in rear
88 cradle, HMS rod end suspension links
Suspension Technique front springs
Corvette 12” rotors, 88 calipers in front
Vented rotors, 88 caliper rotors in rear
Stainless lines front and rear
ADR 17x7 wheels, NEW 235/40/17 Federal 959 RS tires in rear
Addco swaybars
Poly bushings in the front
RD lowering ball joints
Other:
Doug Chase 4pt roll cage with doorbars
Corbeau clubman seats
Zeitronics WBo2,EGT, boost/vac gauge
Rodney Dickman shifter
I wanted to end this by saying that I am typing this without the car in front of me so this is the best I can remember at this moment. Ask any questions and the car will be sold AS IS. It runs and drives but need what I mentioned before anyone beats on it or goes WOT. I can do test drives, I would prefer to be the driver, but if that is the deal breaker, I’m sure we can figure something out. I’m not sure how much money I have put into the car, but between the turbo,cage,seats, engine machine work is over $5000.
Pictures coming later tonight with a video. I will show the initial startup after not touching the car in 3 months.
Video... First start in 3 months. Dont mind my daughter crying in the backround.
Idling after I pulled it out
Here are some picture that I have on my computer in a few various stages:
[This message has been edited by Coinage (edited 05-29-2012).]
Coinage
11-13-2011 12:55 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
ttt
Quad GT
11-13-2011 02:40 PM Click Here to See the Profile for Quad GTClick Here to Email Quad GTSend a Private Message to Quad GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice looking car.
Whats the HP?
Coinage
11-13-2011 02:49 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
With it tuned I would assume in the area of 450whp
EMX5636
11-15-2011 08:05 AM Click Here to See the Profile for EMX5636Click Here to Email EMX5636Send a Private Message to EMX5636Edit/Delete MessageReply w/QuoteDirect Link to This Post
GLWS Matt. I saw this car a while back and it's definitely a steal for the price! Good seller too!
Coinage
11-16-2011 02:40 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Justin!
Bump
PF Flyer
11-16-2011 10:15 PM Click Here to See the Profile for PF FlyerSend a Private Message to PF FlyerEdit/Delete MessageReply w/QuoteDirect Link to This Post
i like that bmw!
Coinage
11-17-2011 09:27 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by PF Flyer:
i like that bmw!
Thanks, that's my M3... That's what placed the fiero on the back burner.
PF Flyer
11-17-2011 10:57 AM Click Here to See the Profile for PF FlyerSend a Private Message to PF FlyerEdit/Delete MessageReply w/QuoteDirect Link to This Post
nice, i have a turbo 3500 fiero that has about 300hp on a conservative tune, and i am actually looking for a e36 325is as my dd, good luck with your sale, 300 in a fiero is AWESOME....450 in a fiero INSANE...
Coinage
11-21-2011 08:35 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
11-28-2011 10:59 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
RandomTask
Total ratings: 140
11-28-2011 10:46 PM Click Here to See the Profile for RandomTaskClick Here to Email RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interested in trade for a chump/lemons racer? You can keep your interior+seats+turn it back to NA (and keep everything) provided engine is built to stock CR.
Also willing to work out more. Pics and specs;
Car will pass tech for both lemons and chump.
Features include;
ATI 15 Gal fuel cell -$600
3 sets Carbotech RX8 Pads $900 (1 set is half used)
New rotors - $100
New Calipers -$200
G-Force 5 point harness - $150
Momo steering wheel w/ quick release -$300
G-Force window net - $50
Wink Rear view $30
SS Brake hoses - $100
Proper built cage with DOM - $350 in material alone
More I'm probably forgetting.
Other installed goodies;
SVT Cams -$80
Lowering Springs = $250
New Clutch/PP $150
SVT Flywheel (lighter) - $110
Koseig Rims w/ shot 205/50/15 Azenis (Tires are garbage)
Stock Rims/Tires
Comes with a plethora of extra parts.
Pics;
Coinage
11-28-2011 10:51 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, but not really looking for a trade. My m3 will be seeing light track duty next year.
Coinage
11-29-2011 08:29 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
dav86fierogt
11-30-2011 05:39 PM Click Here to See the Profile for dav86fierogtClick Here to Email dav86fierogtSend a Private Message to dav86fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
love the car, i seen it on craiglist. i wish winter wasnt coming to slow my work down. any way you can keep til the spring? thanks
Coinage
11-30-2011 07:00 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
I more than likely will still have it in the spring time... No serious offers/interest yet
dav86fierogt
11-30-2011 07:35 PM Click Here to See the Profile for dav86fierogtClick Here to Email dav86fierogtSend a Private Message to dav86fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
how long have you had it up for sale? my fiero only needs a tune and an exhaust too. i got a 3800 sc2 that i just finished besides that. if you still have this in the spring ill bring mine up to see/buy yours. keep in touch so i know if you still got it. 610 507 5588 dave, i live in schaefferstown so it like 25 minutes to get to grantville
Coinage
12-04-2011 09:55 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
dav86fierogt
12-04-2011 11:55 AM Click Here to See the Profile for dav86fierogtClick Here to Email dav86fierogtSend a Private Message to dav86fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
dav86fierogt
12-04-2011 02:44 PM Click Here to See the Profile for dav86fierogtClick Here to Email dav86fierogtSend a Private Message to dav86fierogtEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Coinage
12-18-2011 10:10 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
01-14-2012 12:32 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
01-16-2012 08:22 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
01-30-2012 08:18 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
FreakyFastFiero
01-31-2012 12:07 AM Click Here to See the Profile for FreakyFastFieroSend a Private Message to FreakyFastFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
possibly the fastest fiero on the planet with just a little work.
Coinage
01-31-2012 10:33 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't say it would be the fastest, but it would definitely be quick. Had I done this over I would have went with a standalone ECM vs the stock computer...
Coinage
02-11-2012 12:16 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Coinage
04-17-2012 04:43 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!
skuzzbomer
Total ratings: 78
04-17-2012 07:42 PM Click Here to See the Profile for skuzzbomerSend a Private Message to skuzzbomerEdit/Delete MessageReply w/QuoteDirect Link to This Post
My eyes are still bigger than my wallet...
Coinage
04-21-2012 12:47 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump... need to move this, shoot me some offers!
Coinage
05-02-2012 06:34 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
MeAndMyFi
05-04-2012 10:07 AM Click Here to See the Profile for MeAndMyFiClick Here to Email MeAndMyFiSend a Private Message to MeAndMyFiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent
Coinage
05-04-2012 09:34 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
nitroheadz28
05-04-2012 11:40 PM Click Here to See the Profile for nitroheadz28Send a Private Message to nitroheadz28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'd really think about taking this car if I didn't have so many things going on now.
Question, would it be possible to drive it away?
Coinage
05-05-2012 08:16 AM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would be able to be driven away. Would I recommend it? Probably not just because it barely has any miles on it since getting the motor in.
Coinage
05-09-2012 05:18 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
05-21-2012 10:26 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump
Coinage
05-24-2012 12:14 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump.
kikinz24
05-24-2012 02:53 PM Click Here to See the Profile for kikinz24Click Here to Email kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Sure is nice but if I came home with a 3 rd fiero I would be one of 3 things (d**kless) (single) or (dead). Good luck with the sale tho its definitly nice
Coinage
05-29-2012 07:10 PM Click Here to See the Profile for CoinageClick Here to visit Coinage's HomePageClick Here to Email CoinageSend a Private Message to CoinageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bump!!!!!!!
