| quote | Originally posted by Csell2:
Drilling out that cap has been on my mind, but clearly this issue is caused by something else and I don't want to just be masking the problem; so really I'm torn at what I need to do.
No, you don't want to be messing with the idle stop screw, as it's
not an idle speed adjustment screw. There's a very slight chance on a very high mileage car that whatever surface the end of the idle stop screw rests against has worn away (allowing the butterfly valve to completely close), but that's highly unlikely.
Regarding the rich condition, one thing I would check is to make sure that the single injector in the throttle body isn't leaking fuel past any of its O-rings when the system is pressurized (engine not running).
I might also add that diagnosing an engine
without the ability to see what information the sensors are feeding the ECU is like operating in the dark. You currently have
no idea if one or more sensors are faulty... and unfortunately, faulty
new parts are a common occurrence. You need either a scanner, or a cable that allows you to run scanning software such as
WinALDL on a laptop.
[This message has been edited by Patrick (edited 07-02-2023).]
