Upper section is NPT not Metric thread and maybe the the threads are rotted thru.
Bottom section is a Flare fitting. SAE Not Metric I think.
See
https://www.fiero.nl/forum/...21-2-095637.html#p15If the leak is in the upper section, may need a lot to fix and take off Intake to repair or replace that.
If is in the bottom, depends on just why to fix.
Example: If tube is bad, likely can make a tube out of copper. Or replace whole thing w/ common plumbing parts.
Leak stop only works for short term if works at all for this and many other leaks.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 04-18-2023).]
