Anybody making overlays/appliques for the bezels. Particularly for the 88-shifter surround, dot matrix pattern? If not, any techniques to recreate the patterns?
Thanks
[This message has been edited by Corsair231 (edited 12-02-2022).]
There used to be vendors for those, but I'm not sure if they're still around. Some people have used vinyl "contact paper" with good success. I've never seen anything that looks exactly like the 88 pattern, but there is some carbon fiber stuff that looks... similar.
I had thought about contact paper but finding the right shade/pattern will be a nightmare. No matter what, it would still look just a little off and would probably be very easily damaged. Carbon fiber is an option, but knowing me, I will probably want to wrap all of the other bezels to make them all match. I am planning an auto to manual swap. My auto surround is in very nice shape. I wonder if there is any way to convert mine to work with the manual shifter. I know the ash trays and switch panels are the same size. It would be nice if I could just pop the center out and put a shifter boot on it.
I was thinking about this too. Is the "Dot Matrix" pattern just a sticker applied to a molded plastic part? If so, it should be pretty easy to print and cut
I have customers with large format printers and CNC knife cutting machines that can print and cut such a pattern. Can anyone confirm if this is just a sticker? It would be pretty easy to match the color and pattern. Hopefully there is a CAD file somewhere of all the pieces showing the dimensions of the cutouts, profiles, etc. that would make the job even easier
Originally posted by Corsair231: ... I am planning an auto to manual swap. My auto surround is in very nice shape. I wonder if there is any way to convert mine to work with the manual shifter.
I had thought about doing the same. The automatic shift gate/display is longer/larger than the manual boot, if I remember correctly. You'll likely need a custom boot, and also the plate that goes inside it to hold it down.
the challenge is - how do you align the sticker during install to make sure not to be crooked when placing over opening? Not sure...
The decal would be applied wet. In other words a slightly soapy water would be sprayed on the surface of the bezel to allow the decal to slide around on the bezel. Once lined up, you use a squeegee to remove the water from under the decal. Then set the piece in a warm room so all the water will evaporate and the adhesive will stick.
Does anyone happen to have CAD drawings of the various face plates? If I can get my hands on this, I can get some sample decals printed to match dot matrix color and pattern. Could also do wood inlay look, etc.
I would definitely be interested in an overlay. The shifter area takes a lot of abuse and it's rare to find one that is not munked up in some way. Some overlays I have seen (for mainly older cars) are actually on something like a thin metal plate, almost like a stiff aluminum foil type thing. But for our cars, it looks like a decal would work great. I have a junk bezel coming in a couple of days that I will be able to study a little closer without tearing up my good one.
I'd be thrilled if a decal were available. I've been looking for a nicer automatic shift surround for a lot of years. And mine's not bad - it's just the little scratches and a couple blemishes that bug me.
