Pull the console then ECM cover to see the PROM.
if isn't GM, the label will have other marks to nothing to maybe missing a label/tape over PROM erase window.
Many people and "Chip" companies block data stream to scan.
Scanner only see 1 temp sensor for that engine and often won't help if has coolant problems.
Can have crush pipes, dirt and more blocking flow.
Or if dash gauge just bounces in cold weather, likely nothing is wrong and can't get stant super stat anymore...
See my Cave,
Thermostat,
Crushed Pipe & rest of coolant section
