I have a 1987 v6 GT. Start up brings extreme surging from very low to 2500 rpm and cut out. Was running ok but a little fast. Had my auto tech look and he messed with the diagnostic plug on the ecm. Now if I start and keep the revs up till it warms up it runs smooth but won’t run under 2700. Have replaced IAC valve no help. Dose the ecm need reprogramming. Ecm numbers. Serv no1227170. Fab. 8673. M721121325. Please any ideas welcome. Lombok
The EGR tube may have been a little bit broken, but now, messing with it has made it very broken. The original equipment is fragile after all these years.
Hi Patrick. Car was running ok when I got it. Removed engine to fix oil leaks engine mounts new spark plugs and removed inlet manifold and rocker covers to paint Ran ok after Idle revs a little high 1500. Had cut out problem. Stall at traffic lights. Replaced trans lockup solenoid. Still idle a little high. Idle screw definitely been altered. Checked for vacuum leaks Seems ok. Then got tec with reader, problem since then. Tried procedure jumper on Aldl key off unplug IAC start car adjust idle screw. The plug in IAC.several times Engine warm. Got idle down Ran nice About 900 rpm. When cooled down reverted to problem. Timing has not been changed. I think this car once had NOS on it. Regards Terry
Disconnect the rubber snorkel from the throttle body. Cover the throttle body opening completely with the palm of your hand while the engine is running. If the engine doesn't stall, there's a vacuum leak. As already pointed out, the EGR tube is the prime suspect for a vacuum leak.
Originally posted by Lombok:
Car was running ok when I got it...Timing has not been changed.
Don't assume the ignition timing is correct. Needs to be checked... with the ALDL jumper in place.
[This message has been edited by Patrick (edited 09-29-2022).]
I did your vacuum test. Stalled straight away. Did aldl bridging procedure again , car runs at lower revs eg diagnostic mode But reverts when disconnected. Is there a reader available over there?
Good. Now put your finger just over the IAC port at the front of the TB while the engine is running. The engine should stall (with the throttle closed). If not, the idle stop screw is misadjusted.
I covered the IAC and adjusted the idle screw until running evenly. Still reving high. Disconnected vacuum line from map sensor and plugged line revs dropped to around 900. Is map sensor the problem?
Why would you do that?
Still reving high.
Well yeah, no wonder! There's no way the IAC valve is going to be able to control idle speed if you've adjusted the idle stop screw to allow the engine to be "running evenly" with the IAC port covered.
There are plenty of threads in the archive, including This one, explaining how to reset the idle stop screw if it's been tampered with. Keep in mind that any/all of these methods are based on the presumption that the ignition timing has been properly set (as the ignition timing most definitely affects idle speed).
[This message has been edited by Patrick (edited 09-30-2022).]
