Hey guys!
I've got an 86 SE 4spd with a 98 3.8SC from a Buick regal if I remember correctly. Finally getting back on the project and am running into some issues. Seems to idle great, and drive fairly well under 1/4 throttle. Over 1/4 throttle (especially in 3rd/4th) it will buck, thinking either lean condition or ignition loss. Also, when driving at speed, if I clutch in the motor often dies. Though this may be due to the pcm not having the VSS hooked up and trying to idle down too far, but after wiring that in (and verififying w/ OBDII), still dies. This only seems to happen in 3/4 gears. I did find that the fuel filter was fairly plugged (probably from before I cleaned the tank), so I replaced it which helped some. No codes stored on the PCM. Fuel pressure is steady at ~50 psi. I did install a higher flow pump (ep381). Figured I'd see if anyone else has run into similar issues.
Thanks,
Lukas
4 speed 86 SE with stock 98 3800sc
