  Fiero 2,5l idle issues
Fiero 2,5l idle issues by tomdylka
Started on: 08-13-2021 06:48 AM
Replies: 2 (108 views)
Last post by: phonedawgz on 08-15-2021 01:57 AM
tomdylka
Report this Post08-13-2021 06:48 AM Click Here to See the Profile for tomdylkaSend a Private Message to tomdylkaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello folks,
since yesterday I have problems with the idle of my 2.5l Fiero. I think that this problem can have many causes. However, it is noticeable that the speedometer failed at the same time. The rest of the instruments still work but the speed is no longer displayed. Does anyone know a cause that could explain both problems. Personally, I thought more of an electrical problem? I could be wrong.
Total ratings: 568
Report this Post08-14-2021 11:59 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
VSS on Transmission drives the speedo. Then speedo output speed "data" to ECM and Cruise if car have that options.
VSS could be bad or crap wiring to them or speedo itself.
VSS should output low AC volt then car is jack up so you can turn a wheel by hand.
Total ratings: 290
Report this Post08-15-2021 01:57 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most wiring failures occur at the connector. Unplug the VSS connector (Yellow and Purple wires) and see if one has been pulled out of it's metal terminal.
