  Jerking acceleration in high gears
Jerking acceleration in high gears by 842m4SE
Started on: 07-15-2021 10:26 PM
Replies: 4 (550 views)
Last post by: cajunfiero on 09-22-2022 02:07 PM
842m4SE
Report this Post07-15-2021 10:26 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Having an issue with my '84. When I get into the higher gears - 3rd/4th under gentle acceleration the throttle seems to cut in and out rapidly, making a rough drive. This applies under more throttle as well but it doesn't seem to change much, and is usually most pronounced around 2-3k rpm but also out of that range. Idle is fine and the issue just started pretty recently.
Any ideas?
[This message has been edited by 842m4SE (edited 07-15-2021).]
Skybax
Total ratings: 78
Report this Post07-15-2021 11:03 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like intermittent ignition misfire, possible bad spark plug wire arching. (one of 20 possibilities)
[This message has been edited by Skybax (edited 07-15-2021).]
842m4SE
Report this Post07-16-2021 12:52 AM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
What would the solution to that be? I've replaced the spark plugs but other than that haven't serviced the ignition system. It sat for 23 years if that makes a difference.
[This message has been edited by 842m4SE (edited 07-16-2021).]
Skybax
Total ratings: 78
Report this Post07-16-2021 07:53 AM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Replace park plug wires.
Ignition coil going bad would also behave like that.
Do wires first then test drive, so you can see if it resolved it, before you replace the coil.
Because they are not expensive items, it wouldn't hurt to replace them anyways due to the age of the parts and the car sitting.
Many coils being sold today are junk (even AC Delco), so I recommend buying a Standard Blue Streak Coil through O'Rileys or online, at least that is still Made in Poland at Standard factories.
PS: You also definitely want to replace the fuel filter regardless.
cajunfiero
Report this Post09-22-2022 02:07 PM Click Here to See the Profile for cajunfieroSend a Private Message to cajunfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
did you ever fix this problem? if so what was the fix?
