Ok here is my problem I got a 3800sc 4 speed fiero. Not running the fiero T stat housing using the stock 3800 one. I just installed a new 180 t stat water pump is new also, intake gaskets have been done with 04+ series 3 intake manifold gaskets so not the plastic ones. When driving the car it runs perfectly fine right at cool temps no over heating at all. When I’m idling or in heavy traffic the temp gauge creeps pass the 220 mark. Stock fiero fan using a Derale adjustable fan switch screwed into the lower intake manifold water outlet so I know that it’s accurate. If I read the scanner I can see it getting to 220 that’s when I have the fan switch turn the fan on. It will stay on but the temps won’t come down it will just keep fluctuating. Soon as I drive off or rev the motor the temps come right down does this sound like a air pocket situation? I bled the system from the back keeping the bleeder open car jacked up til all air came out. Overflow bottle up front is half full also When warm.
Pull your radiator and have a shop that repairs radiators check it out. Emphasis on Radiator Shop. They see this stuff daily and can fix or replace if needed. Classical problem, Car heats up while sitting in traffic.. They probably hear this quite often.
Spoon
I just installed a new 180 t stat... I can see it getting to 220 that’s when I have the fan switch turn the fan on.
Originally posted by phonedawgz:
...and set the temp the fan comes on to at a lower point.
Yeah, that's a no brainer for sure. Set it to perhaps 210° on 200° off... or with the relatively low temp thermostat that's been installed, 195° on 185° off.
I would get a better fan with a proper shroud and set the temp the fan comes on to at a lower point.
I saw something or someone on here bought some fan that screws to the existing fiero fan shroud. It is able to pull up to 1300-1600 cfm of air through the radiator. I just don’t know the part number or the link can you possibly help out with this?
I was thinking of going with a lower pressure radiator cap too. I have a 16 pound vented cap up front on the radiator and a 18 pound non vented on the rear in line radiator fill port do you think I should change the rear one?
I’ll definitely lower the temp of the fan controller to come on at a lower temp. I totally forgot to do that anyway thanks for reminding me about it
I don't know anything about the rear rad cap used with a 3800sc swap... but you need a 15-16psi non-vented cap up front. Check the Cooling section (under Powertrain) at The Ogre's Fiero Cave.
I think you just need to adjust when the fan comes on.
You maybe 100% right on this fan is coming on after it gets passed 220 degrees I’ll lower the adjuster on the controller while looking at the scanner and dial it in to come on at 200 degrees and turn off at 180. I’m also installing a non vented 16 lbs cap in the rear so I’ll have 2 of the same pressure caps hopefully this solves the problem
Lol not trying to do that so I have a fill port in the rear over by the stock Grand Prix thermostat housing since I didn’t feel like paying 100+ dollars for the modded fiero housing I just got a inline radiator cap and use that to fill/burp my coolant system. But I feel like since I have a 18 lbs cap I’m making to much pressure in the coolant system for some reason
System pressure really changes how much heat the system can store (more pressure = higher temps) - it has no effect on temperature itself. If the system is running hot only at idle, the problem is most likely the fan... not enough fan, too high a temp, etc.
I use a SPAL fan on my car, its a 16"puller, sorry don't know the part number, but it fitted into the stock shroud with some simple brackets. and really pulls in some air.
------------------ 84SE, aero body, 4 speed and an injected 355 V8
Yea I want to do that but course idk if I type In spal fan it will come up a picture would be awesome if you have one
Thank you big time for this Larry ordering this ASAP to get rid of that crap stock fiero fan. This will definitely help out big time with cooling at idle. I sit in traffic for a good 10-15 minutes before gettin over the bridge to get to work here on the cape. And all I hear is the stock fan running constantly lol surprised it hasn’t burnt out yet. But this proform fan will help out big time
