Hello Everyone!
1984 4spd. No mods. 125k miles. zero rust.
I brought the car out of winter storage a few weeks ago, and after a couple of uses, the driver's side headlight motor started grinding the 37-year-old gears to dust. No problem, as I had a spare rebuild kit from Rodney after I bought two kits a couple of years ago when the passenger side succumbed to age. I replaced the gears and rubber "bushings" and re-greased and put everything back together. Everything seemed fine until I noticed that the headlight motor is "engaging" every 20 or so seconds for a moment and then stops. Like I can hear the relay click on, and the motor tightens (no actual movement of the headlight assembly) and release. It is doing this enough to the point it drained my new battery in three days of non-use.
Another symptom is sometimes when I engage the headlights, my passenger side goes up instantly, but the driver side hesitates and, with no repeatable frequency, decides to come up after the first. To clarify, once the motor engages, the speed of the headlight bucket moving through its motions is just as fast; there is just a random delay in starting the movement.
Does anyone have any idea what is causing this to happen? Any suggestions as to how to fix this?
Thank you.
1984 Base Coupe Red Stock MY8
2002 Grand Prix GTP 40th Anniv. Stock (Now Donor Material)
