😕 "Adjusting" the IAC does Nothing except make sure you don't damage them when installed.
If the tip is too long, will "slam" the seat inside when installed and jam or often wreck the "motor."
Think more like brake piston compression/retract when installing new pads etc. And Two style valves have different direction to "retract" the valve.
If you didn't bind/damage them, the valve will move and "reset" every time you drive over ~ 35mph. After "reset" then can "see" it move in ECM scanner as IAC Step Count in ECM data stream. For Auto Cars, just moving shifter slowly from P R N D and back will move the IAC. Stick cars, carefully load the clutch a bit should do same but don't drag a clutch very long and heat up or burn that.
IAC is 2 phase Stepper Motor driving the valve in/out.
"They" make IAC "Noid light" to see if wiring and ECM works. Is sim to Noid lights for Injectors but have 2 lights that blink as each phase is turned on & off as ECM tries to move the valve.
Note: Year and engine of car often matters because most Noid lights and more have plugs to fit a car.
For Fiero, 84-86 L4 and maybe all V6 have Weather Pack plugs but 87+ L4 uses Metri-Pack plugs for many things including IAC.
The IAC could be "bench tested" but you have to how stepper motors work plus make sure the valve can't move too much or can pop out when turn in close direction and can be very hard or impossible to reinstall the valve part in the motor. "They" make a tool for this but cost a lot of money for tool you likely use 1 time. Unlike Noid Kits have many Noids at HF etc costing <$50. 1 Noid often < $10.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 05-23-2021).]
