My 3800 SC series 2 from a 2002 GTP won't fire. i have 55 lbs of fuel pressure, my oil pressure when cranking is 275-500. There is gas on the sparkplug in cylinder #4 i am getting spark in cylinder #4. And yet she won't fire. i have checked and double checked the sparkplugs and the coil packs are in the right order. i have watched youtube and read about coil pack testing but i don't know what the values should be for the 3800. Anybody know?
thanks jon
------------------ Astronomy says we will find a coded signal from outer space. Then we'll KNOW that life exists there, for coded signals aren't by chance.
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
If the ignition module or the coil pack was bad it would set a code. The first question is, did this engine swap ever start?
Assuming the tach is hooked up does the tach rise 200 rpm during cranking and fall back to zero after cranking?
Can you scan the PCM and see the RPM rise during cranking?
Do you have the fuel pump wired up via the PCM relay. Turn on the key does it run for two seconds and then shut off? Just very lightly bump the starter. Does the fuel pump again turn on for two seconds and turn off?
Not in my car, the engine never started. i just got everything hooked up recentlyAnd when i bot the engine, the car was so rusty that the fuel line had broken, even so we tried to start it, but the alternator was frozen, so no i have never heard the engine run. When i got it to my garage the compression check was 158-170 on all six cylinders.
Originally posted by phonedawgz:
Does it fire on starting fluid?
i will try that and report back.
i can't remember seeing the tach move, i guess i have been focussed on other things. In any case it has the 4 cylinder tach board in it, i will swap in the V6 board i have that is known good....
No scan tool.
i really don't know how it is wired up. Another forum member helped me with the wiring, a forum member that has done 4 3800 swaps, and numerous V8 swaps into Fieros. (i don't know if he would want me to use his name) i will listen for the fuel pump.
jon
Another thing, after dark last nite, i removed the wire from all six cylinders at the coil pack, one at a time, and looked for spark when i cranked. All six had spark. i had to use the reflection of the spark on the sailpanel cuz i have no one to help me, but my son is coming Monday nite for a cuppla weeks so i can try it then.
She fires on quickstart, but doesn't respond to throttle position. So i guess that means that the electrical system is good enuf to run her. However i don't hear a pump running when i turn the key, yet i have 55 lbs in the fuel rail. Could the injectors be bad/plugged? Or electrical problems to the fuel pump? In my excitement i still have not looked at the tach.
my buddy says that they drove her into the yard before they decided to sell her.
jon
[This message has been edited by longjonsilver (edited 04-11-2021).]
First step. Check to see if the VATS has been disabled in the program. You will have spark but the injectors will not energize if it is still active.
Originally posted by Dennis LaGrua:First step. Check to see if the VATS has been disabled in the program. You will have spark but the injectors will not energize if it is still active.
Well the programming was done by GM Tuners - Sinister Performance, so i assume that the VATS is disabled correctly. Thats primarily why i sent it to him.
jon
