| quote | Originally posted by AL:
Does anyone have a pic of the hole where the distributor goes in ? The reason is that on my Indy the distributor doesn’t turn, but when I pulled the dis I noticed that there isn’t a cross where the distributor goes on so when the cam rotates the distributor turns.
If it is fully engaged and the distributor rotor does not turn when the engine is being turned over with the starter, the timing gear is probably stripped. Can you see the cam gear turning? You may need a new timing gear. If it is that replace with th steel version not the nylon one.
