  Auto Gear Shifter Light Bulb Socket Repairable or Source for Replacements?
Auto Gear Shifter Light Bulb Socket Repairable or Source for Replacements? by reinhart
Started on: 02-15-2021 12:44 PM
Replies: 7 (216 views)
Last post by: theogre on 02-23-2021 10:43 AM
reinhart
Report this Post02-15-2021 12:44 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got a few bulb sockets that have broken off tabs. The main areas are the shifter surround and the cigarette lighter areas.
The socket that goes in the auto transmission gear selector is my biggest concern right now. The ash tray sockets have also have missing tabs and fall right back out.
Any one come up with a good way to repair the sockets? Super glue would hold them in but would like to be able to remove them esp the auto trans gear light socket.
Also are they available as replacements?
[This message has been edited by reinhart (edited 02-15-2021).]
fierosound
Total ratings: 287
Report this Post02-15-2021 01:42 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
T1 3/4 twist lock socket pigtail
https://www.jkllamps.com/specialty/sockets/2945-6B
https://hidkitpros.com/shop/t574-socket/
See Ogre's Cave Lightbulbs
[This message has been edited by fierosound (edited 02-15-2021).]
reinhart
Report this Post02-15-2021 05:35 PM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. Those look like the ones for the ash trays....The transmission gear light socket looks different. Got a source for that one?
fierosound
Total ratings: 287
Report this Post02-17-2021 10:53 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought all 3 were the same. Maybe someone has an idea on that.
Mickey_Moose
Total ratings: 145
Report this Post02-18-2021 01:26 PM Click Here to See the Profile for Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
for the gauges socket:
https://www.mouser.ca/Produ...ptf0WO0nwd3p89DOBw==
But you should be able to find them at most auto parts stores. You are looking for the 2933 lamp holder.
I just go to a local pick-your-parts and grab a handful from other cars - they are all the same, but you have to look at the older cars, the newer cars use LED or a different type of bulb, but anything from the 80's will have them and even into the 90's.
[This message has been edited by Mickey_Moose (edited 02-18-2021).]
Report this Post02-19-2021 03:06 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Year of car.
Some early years list AT shift bulb as 194. Others are 70.
194 is same Watts as 70.
I would find dimmer bulb. Console Light have nasty habit bounce off windshield and be annoying or worse at night.
I used 73 or 74 and even they are annoying. blown again and didn't replace in 15+ years.
reinhart
Report this Post02-23-2021 05:55 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi I'm looking for the plastic SOCKET not the bulbs. I especially need the gear selector socket that lights up with P R N D 2 1. Anyone got a spare good used one if unavailable new?
Report this Post02-23-2021 10:43 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Other sockets for 70 size bulbs are likely cooked. You have to find very low mile car before finding a good one.
Try digikey etc or web search for sockets for T-1 3/4 wedge base bulbs.
But Some "store" only sells sockets in 10 to 100 count packs.
Maybe this... Found on google: T-1 3/4 wedge base socket and just looked at images. Ashtrays likely is same.
https://www.superbrightleds...e-socket-wired/1151/ but out of stock
If 194 may have pigtail for them too.
