You are attempting a 3800 Series 1 engine swap. In 1990 those engines were all normally aspirated. Its not a very popular swap because for the work/cost the end result is only 165HP, not a significant improvement. If you still want to do that swap and mate that engine to a stick you will need a specially cut flywheel. I have no idea what the thickness it should be on a series 1 engine. On the series II engine they are cut in the area of .82 in thickness and balanced to the flexplate.
