| quote | Originally posted by ericjon262:
I have C5 fronts on all four corners, it seems to stop nicely, that being said I haven't hammered down on it yet, and ideally it needs a larger MC. I have been investigating options for a drum in hat setup, but most will likely not clear the C5 front calipers, leaving a spot caliper as possibly the only easy solution.
It's your caliper adapters I'm using from RFT...
I have notes buried somewhere where I did the bore calculations to run 4 front C5/C6 calipers and the 84-87 master cylinder 1" bore, .015 larger than the 88, was spot on...... but I need to make sure I didn't size it for the 'stock' C5/C6 front rear setup...just haven't gotten to brakes yet..... The fiero store sells an 11% larger reman'd bore as well..
The best rear ebrake caliper I've seen is from the Dodge Viper.
EDIT: I just remembered where my notes were for my calculations.... for the stock C5/C6 setup it's a 1" bore, for running 4 fronts, which gives a total of 19.25 sq. in. of piston area, a 1 1/8" bore would be required. Sounds like the fiero store reman'd master cylinder or the S10 master would work well...
[This message has been edited by msweldon (edited 02-03-2021).]
