| quote | Originally posted by skywurz: Those old computers were far from standardized and wouldn't expect a scan tool to work. |
Another w/o a clue claiming whatever...
Old ECM are not "Standard" like OBD2 vehicles but Scan tools are used by every maker w/ "OBD1" vehicles and while slow to read often the data you get
can save many hours of time to find whatever is wrong. In case of any DIS engine, is Only thing to tell you info you need as Often Doesn't even have timing marks on crank pulley/balancer.
Common example to all cars: Reading Ω at ECT and others is often useless because of crap wiring or iffy ECM. Scan the ECM tells you coolant temp in seconds and tell you sensor lying or bad for bad sensor or crap wires and don't need to dig out ECM to Ω the wires.
Also Crap GM wire/plugs to ECT is why you
can't get old ECT sensor. To replace you must upgrade for MetricPack plug and use new sensor. 87 started w/ new ECT plug and most parts outlets not just GM dealers Stopped carrying old unit. For many years many ECT sensor had right plug in the box and directions to use it.
| quote | Originally posted by RWDPLZ: Fieros work great with similar vintage scan tools, ...
OP may have bad wiring on his diagnostic connector, that would be the first thing to rule out. |
Or a iffy scan tool/cable. Snap-on can break. Run tool on other old GM vehicle ideally w/ data stream on ALDL M. You can see E or M because only 1 is wired in ALDL port.
Many ALDL cables and sockets in cars have problems. More so w/ sockets in cars because fools push large "wires" into them to flash code on the dash and wreck the ALDL "pins." Scanners for GM cars must get good connection w/ ALDL A B & E
OR M at minimum depending on Engine and Year of car.
If ALDL A B or both is wreck then expect problems scanning... As One is the ground and other sees "Resistor value" (1 to several real resistors or emulation of same) to trip ECM data stream to E/M pin or to read DTC on scanner screen.
Pull Console to get at ALDL back and pull out "pins" to inspect/fix ends. Think release pins same method w/ "tool" in See my Cave,
Defect & Connection notes[This message has been edited by theogre (edited 01-27-2021).]
