  '84 Increasing idle
'84 Increasing idle by 842m4SE
Started on: 01-14-2021 02:46 AM
Replies: 2 (148 views)
Last post by: theogre on 01-14-2021 10:24 AM
842m4SE
Report this Post01-14-2021 02:46 AM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I recently got my '84's duke going for the first time in 24 years, and then it had a high idle, starting at 3 and increasing to around 4k before I turned it off. I replaced most of the vaccum lines and now it starts at 2k and slowly increases up to around 3-3.5k after around 3 minutes. Fixing the lines seemed to fix a lot of the high idle, but I'm not sure what could fix an increasing idle. Any ideas? Thanks!
rubyredfiero
Total ratings: 58
Report this Post01-14-2021 08:01 AM Click Here to See the Profile for rubyredfieroSend a Private Message to rubyredfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
The EGR valve could be stuck open, the EGR gasket to the manifold could be leaking, the diaphragm could be leaking or the hose from the EGR to the TB is bad. I had the same problem in two Fieros and just removed the EGR valve and blocked it out completely.
Report this Post01-14-2021 10:24 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Vac Leaks
But note: If you can't/won't drive the car... likely had to replace battery and ECM needs to "reset" somethings and will have high idle until drive > 35mph for a few blocks minimum.
Does idle drop some when bump the gas? Unless very cold to freezing weather should slow down some but will often still have to Reset before you see normal idle.
If weather is cold/freezing then won't see normal idle w/ ECT seeing cold coolant. If ECT or wires to it are iffy then tell bogus coolant temp to ECM does same thing. Need ECM scanner to really see sensor data.
Car not run in months to years then have other problems now or soon.
Example: Water Pump seal is likely to fail because no/weak coolant and rust on shaft eats it. Good Coolant is lube for the seal and anti rot for just about everything else. Car sitting years or decades means no protection except glycol keeping system from freezing.
Likely needs brake fluid and other brake problems fix. See rest of cave for coolant and brakes.
