  DRIVER'S DOOR STUCK
DRIVER'S DOOR STUCK by Lone Ranger
Started on: 01-13-2021 03:39 PM
Replies: 1 (330 views)
Last post by: theogre on 01-13-2021 04:23 PM
Lone Ranger
Report this Post01-13-2021 03:39 PM Click Here to See the Profile for Lone RangerClick Here to visit Lone Ranger's HomePageSend a Private Message to Lone RangerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to bypass surgery and related fun, my '86 sat for several years. The driver's door won't open and since crawling across from the passenger side is a feat left to children, I went in through the roof. (video on FB if anybody wants to see an old fat guy pull that off) Is there a way I can get at the internal mechanism from the inside with the door closed? Passenger side was also sticky until I got it open and lubricated the lock mechanism. Mechanical linkage seems to be intact on the driver's side, so I suspect the actual latch itself is stuck together enough to prevent the usual pull from releasing it. HELP! And thanks!
Report this Post01-13-2021 04:23 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sound like Door is Locked since can't open inside or outside.
Unless is cold and was wet and door seal can freeze to the metal.
If lock and/or both lock rods have problems. Unlikely. Is a way to "pick" open a door w/o damage or using "slim jim" that isn't going to work w/ "Fiero type" doors. "Standard" slim jim is made to work w/ lock arm goes up/down not sideways like Fiero and many others are setup.
But...
First pull inside door handle trim to look at door handle.
Door handle can bend or break under trim and won't pull the rod to open the door.
Lock "button" pries off lock rod.
then 2 "hidden" screws hold the trim.
Outside handle can have similar problems but can't remove easy w/o taking outer skin off and can't to that w/o opening the door.
If that seems to work...
pull lock rod to front.
pull open rod to front or pull handle.
Have helper to hit the door outside about where latch is. If latch is stuck, hitting and pushing can shake the latch guts to release.
If that helps, may not shut until you get spay oil in the latch. Don't get sloppy or likely spray window parts and make a mess. Some window parts hate oil etc on them.
