  Allante or Cadillac 4.9 adjustable fuel pressure regulator?
Allante or Cadillac 4.9 adjustable fuel pressure regulator? by Johns 4.9
Started on: 01-08-2021 05:19 PM
Replies: 15 (405 views)
Last post by: Will on 01-18-2021 09:56 PM
Johns 4.9
Report this Post01-08-2021 05:19 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hello Fiero Guys and Gals,
Anyone have success adapting or building an adjustable fuel pressure regulator for the Allante 4.5 engine or the Cadillac 4.9 engine? I'm running out of ideas. Any suggestions or comments would be appreciated. Thanks!
Cheers,
John
Report this Post01-09-2021 11:24 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may be possible to cut the fuel pressure regulator from the fuel rail and weld/solder in a piece of fuel line. Then you can cap the return end and be able to locate an adjustable fuel pressure regulator with a T on the fuel line near the fuel filter. Just an idea but I believe it may work.
Total ratings: 236
Report this Post01-09-2021 02:53 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Northstar regulator is factory adjustable. IIRC, it fits the Allante and 4.9 (and most other GMs of the era...) fuel rails
Report this Post01-09-2021 03:29 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
It would have to look like what is used on the 4.9L Cadillac engine;
I don't know of any direct fit adjustable regulator but maybe you can point the OP in the right direction.Looking on Rock Auto they don't seem to list a N* fuel pressure regulator anymore.
[This message has been edited by Dennis LaGrua (edited 01-09-2021).]
Report this Post01-09-2021 05:51 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
10+ years ago, guys were adapting the Aeromotive FPR for the Chevy LT-1 #13106.
https://aeromotiveinc.com/p...t/gm-lt-1-regulator/
Report this Post01-09-2021 06:45 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
That regulator looks like it would be a direct fit on the 4.9L Cadillac rail but at $222 its a pretty expensive option.
Johns 4.9
Report this Post01-09-2021 06:48 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys! This may be a cheaper option?
John
https://www.ebay.com/itm/Ac...gulator/303769957044
Spadesluck
Report this Post01-10-2021 12:50 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
John
Do it and let me know if it works so it saves me the trouble.
Report this Post01-10-2021 09:51 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quick look on RockAuto and all the regulators for the 1993 LT1 and 1995 4.9 are the same part number.
[This message has been edited by fieroguru (edited 01-10-2021).]
Total ratings: 236
Report this Post01-10-2021 07:25 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the Allante unit different than the PFI 4.9?
Report this Post01-10-2021 09:48 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. ACDELCO 2173052
Johns 4.9
Report this Post01-10-2021 11:26 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Unfortunately, that isn't the Allante regulator. Much different, not even close. Here is a pic of the Allante regulator.
Cheers
Spadesluck
Report this Post01-11-2021 12:48 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is the exact problem I had trying to source a regulator a while back. The pictured regulator is not what is on the Allante rail but all part numbers point like it is.
[This message has been edited by Spadesluck (edited 01-11-2021).]
Johns 4.9
Report this Post01-11-2021 02:10 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I am working on for the Allante adjustable regulator.
Cheers
Johns 4.9
Report this Post01-18-2021 08:53 PM Click Here to See the Profile for Johns 4.9Click Here to visit Johns 4.9's HomePageSend a Private Message to Johns 4.9Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is what I have come up with for an adjustable fuel pressure regulator for the Allante 4.5 engine. I will test in the next couple of days.
Cheers
Total ratings: 236
Report this Post01-18-2021 09:56 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
What do you have on the inlet? Compression fitting on the factory tubing? or Bundy adapter?
For the inlet, have you thought about making a fitting that would plug into the fuel rail, but then just have female 1/4" pipe threads? It could be turned in a single setup on a lathe, then oriented the direction the added fitting would need to go.
