  Thermostat fitment issues?
Thermostat fitment issues? by Color_cast
Started on: 01-02-2021 03:18 PM
Replies: 2 (101 views)
Last post by: Color_cast on 01-02-2021 05:48 PM
Color_cast
Report this Post01-02-2021 03:18 PM Click Here to See the Profile for Color_castSend a Private Message to Color_castEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys, I'm not sure if i'm completely off my rocker here, but I've visited this forum a few times in the past and found very helpful information so I thought I'd reach out and see if anyone has had a similar issue.
I've got an '87 GT that I have recently purchased. It's been driven very, very sparsely over the last 15 years or so in that it only has 49k miles on it. I recently went to swap the thermostat as the old one was sticking, but when I went to replace the cap, I could not get it on without a herculean effort. Upon closer inspection, I realized that the thermostat itself sticks out of the housing by a small amount. I measured the new thermostat against the old one and even bought a second one to make sure, but they are all the same size. The housing itself appears to be stock so I'm confused about what could be the issue here. If I remove the thermostat the cap fits fine.
Any ideas?
Total ratings: 458
Report this Post01-02-2021 03:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Apply some grease to the rubber seal of the thermostat before installing. The thermostat needs to snap down into position. Don't force it though. There might be some corrosion in the groove it's supposed to pop into. If it's bad, clean it up with some emery cloth. (Try not to let any crud get in the coolant.)
[This message has been edited by Patrick (edited 01-02-2021).]
Color_cast
Report this Post01-02-2021 05:48 PM Click Here to See the Profile for Color_castSend a Private Message to Color_castEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I had no idea that it was supposed to snap into place. That might be the whole issue. I'll try a bit of grease and see how it goes.
