⚠️ Warning: You Must have locking "tabs" on pads for rear brake.
W/o them the piston can twist during normal braking and use of P-brake.
That can cause major pad drag causing very big problems like brake fluid boil or fires.
Return them to Amazon. You can't safely mod them to fit.
88 rear cal w/ bridge off then can use same clamp method for older cars. Other then bit different diameter, 88 is
No Different then older Fiero or other cars w/ same pistons.
88 had special retract tool only to save time to GM Dealer Service Dept.
If you really want one watch Ebay.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 12-31-2020).]
