  Smoking or steaming engine gasket
Smoking or steaming engine gasket by 842m4SE
Started on: 12-30-2020 05:12 PM
Replies: 4 (381 views)
Last post by: 842m4SE on 12-30-2020 09:04 PM
842m4SE
Report this Post12-30-2020 05:12 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ran my '84 Fiero earlier today for the longest time it has run since it was parked in '97, and it was working normally for a while, besides an oddly increasing high idle. After running it for a bit and going in to check the gauges, I come out to check on the engine and there is either steam or smoke coming from one of the gaskets on the engine, along with a few drops of coolant around it.
I'm guessing the gasket would need to be replaced. Is that the solution, or could this be indicative of a greater problem? Also, how would I go about doing it? Thanks.
fierosound
Total ratings: 286
Report this Post12-30-2020 06:35 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Gasket leak. You have the "old style" thermostat housing.
You need the blue Felpro gasket PN 35062
https://www.fiero.nl/forum/Forum2/HTML/144348.html
Report this Post12-30-2020 06:48 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be bad Cap and coolant ran down but T-stat housing likely rotted/damage letting the gasket leaked.
New T-stat housing part is hard to find.
I'm told is ACDelco # 15-80794 GM# 10038440 but no pictures on few sites claim to have them.
Should be New Tube/Housing w/ own special gasket.
Bad news, isn't only thing iffy or dying as result of being parked or dead coolant. Example: WP Seal is known to fail after parked for months to years then engine runs again.
[This message has been edited by theogre (edited 12-30-2020).]
842m4SE
Report this Post12-30-2020 08:37 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, that is good to know. Would it still have rotted out in a dry climate? Things seem to be in not quite as bad condition because it is a CA car from a hot and dry area.
Also, would it be good to just replace the water pump while the coolant is drained?
Thank you for the advice and info.
842m4SE
Report this Post12-30-2020 09:04 PM Click Here to See the Profile for 842m4SESend a Private Message to 842m4SEEdit/Delete MessageReply w/QuoteDirect Link to This Post
842m4SE
Member since Sep 2020
Ok, thank you for the link and info.
