  Which 2.8 in my GT?
Which 2.8 in my GT? by CSM842M4
Started on: 11-20-2020 01:12 PM
Replies: 4 (211 views)
Last post by: CSM842M4 on 11-27-2020 05:38 PM
CSM842M4
Report this Post11-20-2020 01:12 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I bought my '86 GT, I was told it had a little rod knock. Bought it anyway. The "little" turned out to be greater than I thought. #4 journal on the crank is such that the biggest undersize rod bearing (1.00 mm) doesn't even touch the Plastigage. SO, I'm shopping for a fresh crankshaft. My part-time employer/FLAPS lists two different main bearing diameters for replacement cranks for the '86 2.8, and lists different casting numbers which I assume are for the crankshafts. My question: is there any way to tell which diameter mains I have, and therefore which replacement crankshaft I need, without removing the oil pan? Maybe a block casting number also identifies the crank? I mean, yeah, the pan is going to have to come off anyway, I would just like to do it later rather than sooner... Any/all input, you know the rest. Thanks in advance - Chris
Report this Post11-20-2020 02:18 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 463
Report this Post11-22-2020 10:40 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry. Please disregard.
[This message has been edited by Raydar (edited 11-22-2020).]
CSM842M4
Report this Post11-22-2020 02:15 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Gall757. Hopefully my tablet at home will let me see the images in that post; work computer blocks such things. I'm hoping there will be information that will allow me to identify the crank without pulling the pan. I'm a little skeptical, though...
CSM842M4
Report this Post11-27-2020 05:38 PM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Judging by the note at the bottom of the first page, since my GT is an '86, it should have the second-design, big-journal and bigger oil galley crank. I'm anxious now to get the cradle bushings done on the wife's car and get mine back in to confirm. More as it happens... - Chris
