  What's widest rim size on front for an '86 / stock suspension?
What's widest rim size on front for an '86 / stock suspension? by Squall86GT
Started on: 11-18-2020 11:20 PM
Replies: 7 (228 views)
Last post by: Will on 11-20-2020 12:24 PM
Squall86GT
Report this Post11-18-2020 11:20 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks in advance
Squall86GT
Report this Post11-18-2020 11:25 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm researching wheels. Hmm, looks like I also need to know hub size, min offset and max offset - anyone know those?
skywurz
Report this Post11-19-2020 01:30 AM Click Here to See the Profile for skywurzClick Here to visit skywurz's HomePageSend a Private Message to skywurzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kinda silly to only run wheels on your car
qwikgta
Total ratings: 84
Report this Post11-19-2020 10:35 AM Click Here to See the Profile for qwikgtaSend a Private Message to qwikgtaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum. Please use the search function, this question has been asked 1357 times. If you don't want to use the Pennocks search, you can type this into google | site:fiero.nl widest wheels | then in the future, you can replace any keyword you want after the .nl and it will search Pennocks for that keyword.
Rob
[This message has been edited by qwikgta (edited 11-19-2020).]
cvxjet
Report this Post11-19-2020 03:56 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been doing some cal-cul-a-mating and found out something interesting; The C7 Grand Sport has 285 mm tires up front and 335 mm tires in back. My 1985 SE V6 Fiero weighs 2600 lbs (No AC/PW/PM) The C7 GS weighs approx' 3600 lbs...The ratio is 1.38 to 1.
So those 285 mm tires up front come down to 205 mm wide tires.
The 335 mm rears come down to 245 mm wide......
Too much >>Un-Sprung<< (And ROTATIONAL) weight will KILL the performance of your Fiero...Keep the wheels and tires as light as possible....
IMSA GT
Total ratings: 250
Report this Post11-19-2020 08:15 PM Click Here to See the Profile for IMSA GTSend a Private Message to IMSA GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rob
Normally I don't comment on this but because it is a wheel question, I'll have to agree with you. This topic has been covered almost once a week and has been beaten to death on here.
fierosound
Total ratings: 286
Report this Post11-20-2020 11:27 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right click and SAVE this picture (it will larger and readable)
[This message has been edited by fierosound (edited 11-20-2020).]
Total ratings: 236
Report this Post11-20-2020 12:24 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've run C5 Corvette 18x9.5-61 rears on the rear of my '87 with 1" spacers/adapters. That means that an 18x9.5-36 would fit (61-25=36). On an '84-'87 car, you can downsize that to 17x9.5-36 without the wheel hitting the knuckle.
Why am I talking about the rear when you asked about the front?
Well for Fieros near the stock V6/stick weight distribution (~45/55), the front wheel & tire want to be 80% as wide as the rear for best handling. That means max out the rear and then go 80% of that on the front.
That results in a 7.5" wide front wheel, which is an easy fit.
[This message has been edited by Will (edited 11-20-2020).]
