  Clutch pushrod question...
Clutch pushrod question... by CSM842M4
Started on: 11-16-2020 10:21 AM
Replies: 4 (139 views)
Last post by: fierofool on 11-16-2020 04:35 PM
CSM842M4
Report this Post11-16-2020 10:21 AM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Am replacing the clutch slave in my '86 GT. While removing the old broken one, I noticed that the pushrod had been whittled out of square key stock. As such, I'm not confident that it's the correct length. I will probably end up making an adjustable pushrod, but I would like a ballpark to start with. Anybody know how long the factory pushrod was supposed to be?
Report this Post11-16-2020 11:11 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The '86 GT had both 4 and 5 speed transmissions. If you have a 5 speed, the push rod is like this:
[This message has been edited by Gall757 (edited 11-16-2020).]
CSM842M4
Report this Post11-16-2020 11:33 AM Click Here to See the Profile for CSM842M4Send a Private Message to CSM842M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Whoops! Forgot to mention - 4-speed. For now...
Report this Post11-16-2020 12:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Uneven wear or breaking of the push rod maybe sign the pedal arm is bent/twisted.
OE pedal is "weak" and easier to bend/twist for any problems on trans end or the clutch itself.
Many clutch arm in rear gets bent too and clutch hyrdo has a harder time to work.
Total ratings: 154
Report this Post11-16-2020 04:35 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4-speed slave pushrod is 5 5/8 inches long.
The new slave didn't come with a pushrod? If you have to make a replacement, be sure it's a properly hardened rod, else it will bend under use and fall of the clutch release arm.
