  Turns over but will not start... Help a new Fiero owner out...
Turns over but will not start... Help a new Fiero owner out... by robmorais
Started on: 11-12-2020 06:39 PM
Replies: 13 (418 views)
Last post by: fierosound on 11-17-2020 09:10 PM
robmorais
Report this Post11-12-2020 06:39 PM Click Here to See the Profile for robmoraisSend a Private Message to robmoraisEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just picked up an 86 with the 2.8 and manual trans. I need some help getting this thing running... The car turns over but will not run... Here is what I have done or checked...
1. Spark to the plugs (really just checked one of them)
2. There was zero fuel pressure at the valve so I changed out the fuel pump and sending unit.
3. the ECM, Distributor Cap and Rotor were changed by the previous owner just before I got it and I had the ECM tested it was fine on 3 tests...
4. Fuel Filter changed.
5. Coil tested with volt meter
It will turn over but will not run. When I pump the gas it makes a "popping" sounds.
I really need some help... What am I missing? What could it be?
Thanks,
Rob
Robert Morais
Report this Post11-12-2020 08:07 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum!
Do you know the history of the car? The popping sounds suggest that it is getting both fuel and spark, but not when it does any good. There could be a timing issue as well as a few other problems...the first thing to check is if the spark plug wires are in the right place. Has it run since the parts were replaced?
robmorais
Report this Post11-12-2020 08:27 PM Click Here to See the Profile for robmoraisSend a Private Message to robmoraisEdit/Delete MessageReply w/QuoteDirect Link to This Post
The wires are in the right place on the Dist cap 1-6 according to the diagram I found on line. Is there an easy way to check the timing? I am not sure when the car stopped running but I believe it was after the cap/rotor were replaced. - but i am not sure...
Thanks,
Rob
Robert Morais
[This message has been edited by robmorais (edited 11-12-2020).]
fierosound
Total ratings: 286
Report this Post11-12-2020 08:48 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like the timing was messed up during the "tuneup".
You have to get cylinder #1 to TDC and see if timing mark lines up.
Then check that rotor is pointing to correct cylinder #1 spark plug wire.
Also, fuel pressure should be 42 psi at "Key On"...
[This message has been edited by fierosound (edited 11-17-2020).]
Doug85GT
Total ratings: 128
Report this Post11-12-2020 10:33 PM Click Here to See the Profile for Doug85GTSend a Private Message to Doug85GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check the fuel pump relay. A quick check is to switch out the connector with the one next to it. Make sure you put a piece of tape or mark the connector so you don't forget which is which.
robmorais
Report this Post11-12-2020 11:35 PM Click Here to See the Profile for robmoraisSend a Private Message to robmoraisEdit/Delete MessageReply w/QuoteDirect Link to This Post
When i turn the key i can hear the relay click, and when i did a pressure test the fuel using the Schrader valve it tested at 42.
Thanks,
Rob
Mike in Sydney
Report this Post11-13-2020 12:02 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check this site. https://www.wc-autoparts.co...-6-cylinder-engines/ It has the firing order and the spark plug location as well as where the number 1 plug lead is located on the distributor when the timing is set correctly. Cylinders 1, 3, & 5 are located closest to the trunk compartment. The transmission will be on your left.
Mike in Sydney
robmorais
Report this Post11-17-2020 03:38 PM Click Here to See the Profile for robmoraisSend a Private Message to robmoraisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for the newbie question... but... The spark plug wires are in the right places. When I tried to start it using starter fluid squirted into the intake it backfired and lit the fluid on fire! That was fun!
Can I check the timing without having to remove the timing chain cover etc... any help would be appreciated!
Thanks,
Rob
Report this Post11-17-2020 03:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Checking/changing the ignition timing has nothing to do with the timing chain. It has to do with rotation of the distributor body in relation to the rotor.
You also need to buy or borrow a timing light.
[This message has been edited by Patrick (edited 11-17-2020).]
Report this Post11-17-2020 05:01 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That was fun!
That tells you that the spark happened before the intake valve closed....way too soon to be useful. It's possible that the rotor is not on the shaft right.....pointing backwards.
[This message has been edited by Gall757 (edited 11-17-2020).]
robmorais
Report this Post11-17-2020 07:53 PM Click Here to See the Profile for robmoraisSend a Private Message to robmoraisEdit/Delete MessageReply w/QuoteDirect Link to This Post
After looking all over the internet I found one guy who suggested switching the wires on the Distributor cap http://www.gafiero.org/bbs/index.php?topic=1415.0 1 to 4 2 to 5 3 to 6... it started right up!! Sounds good! Thank your everyone!
Rob
Report this Post11-17-2020 08:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That guy was Fierofool.....heh.
Report this Post11-17-2020 08:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, the timing was out 180°+/-. You still need a timing light to make sure it's correct... and not just close.
fierosound
Total ratings: 286
Report this Post11-17-2020 09:10 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup. What I suggested to check.
[This message has been edited by fierosound (edited 11-18-2020).]
