isn't the sender is iffy...
More likely is something w/ oil pump and regulator likely on the pump.
Some "normal" and more w/ High volume pumps can Spike OP because reg can't dump oil fast enough at high RPM.
Put a mech gauge on engine reads 100+ PSI and likely see this.
⚠️ Warning:Many Oil Filters can fail w/ High OP too. If can, flange or seal doesn't fail, the filter media can.
Many GM Bypass valves are in the engine Not in the filter and only flows some oil. Any engine uses PF47 52 and others have no bypass valve in the filters. This valve can "wear out" or otherwise fail or be open a lot because have collapse/plug filter media or pump/reg problems.
ACDelco has/had the bypass for OE Fiero engines because many still use same valve.
In cold weather the valve can open too depending on weather temp and oil used. Is why most GM and many others vehicles call for 5W or 0W oils.
10w is
heavier at higher temps and raise OP even higher.
See
https://www.fiero.nl/forum/F.../HTML/143166.html#p5 and DL the API PDF Read oil viscosity grade at bottom.
thick oil can wreck the SC and cause more problems. If you look in OM for car w/ that engine from factory is Oil Spec is likely 5W-30 to 0W-20. New cars even have 0W-16 from the factory.
