  heater problem
heater problem by spirit
Started on: 11-02-2020 09:19 AM
Replies: 5 (400 views)
Last post by: spirit on 11-07-2020 11:17 AM
spirit
Report this Post11-02-2020 09:19 AM Click Here to See the Profile for spiritSend a Private Message to spiritEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a recuring problem with the heater on my 86GT. I am on the 4th heatr core and it is leaking also the water lines under the car are starting to have leaks replacement are not available. Does anyone have a FIX? Open to sugestions.
Report this Post11-02-2020 10:49 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
4 heater cores over 30 years is almost reasonable, but my car is on #2. Either you are buying junk heater cores, or something is wrong with your coolant. Are you using just water?
[This message has been edited by Gall757 (edited 11-02-2020).]
Total ratings: 154
Report this Post11-02-2020 01:44 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jack, I found copper/brass heater cores at Rock Auto. But, like everyone else's aluminum cores, they are about 1/4 inch short. Best thing is that they are new copper/brass and I think solder probably takes better to that than aluminum.
Total ratings: 458
Report this Post11-02-2020 02:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I was wondering.
Total ratings: 568
Report this Post11-02-2020 03:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes or Even weak coolant, < 50% Coolant, can cause problems.
Electrical problems can kill coolant parts too as coolant tries to be a ground to whatever.
spirit
Report this Post11-07-2020 11:17 AM Click Here to See the Profile for spiritSend a Private Message to spiritEdit/Delete MessageReply w/QuoteDirect Link to This Post
Using a coolant mixtture and have started adding tablets to cut down on electrolis. Recommended for the 4.9 auto.
