  88 Fiero Formula Temperature Gauge
88 Fiero Formula Temperature Gauge by Schatz
Started on: 10-28-2020 07:36 PM
Replies: 4 (351 views)
Last post by: theogre on 10-30-2020 08:14 PM
Schatz
Report this Post10-28-2020 07:36 PM Click Here to See the Profile for SchatzSend a Private Message to SchatzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello all, I seem to have an issue with the temperature gauge in my Fiero. The gauge is constantly pegged right and to add to the the temperature warning light doesn’t light up when starting the car. I grounded the two green lines coming out from the temp sending sensor. When I did this I was able to get the temperature warning light to light up but the temperature gauge shows no movement still. I was wondering if anyone had any suggestions on how to diagnose this issue. Thank you
Report this Post10-28-2020 08:14 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is probably the most discussed and documented issue on the forum.....going back years. If you have not done so already, you should read this overview of the operation of the Fiero temp gauge.
http://gafiero.org/temp_gauge_repair.shtml
Total ratings: 568
Report this Post10-28-2020 11:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pegged and stay there = often sender is dead or wire to it is open.
If messed w/ dash then can be bend "pin" on the dash "board" not connecting w/ plug.
Schatz
Report this Post10-29-2020 09:20 AM Click Here to See the Profile for SchatzSend a Private Message to SchatzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, looks like I will be buying temperature sending unit. I’ll post if that solves the issue.
Total ratings: 568
Report this Post10-30-2020 08:14 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unplug the sender and short the plug to engine will tell you if rest works.
0Ω to ground is "0" side of most gauges.
other pin just light temp light.
