  Fiero wheel studs sizes
Fiero wheel studs sizes by Meatpiemonday
Started on: 10-25-2020 12:44 PM
Replies: 3 (124 views)
Last post by: Meatpiemonday on 10-25-2020 03:28 PM
Meatpiemonday
Report this Post10-25-2020 12:44 PM Click Here to See the Profile for MeatpiemondaySend a Private Message to MeatpiemondayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm about to start my Lebaron brake upgrade and when I was about to press in my longer studs I noticed that I had 2 different sized wheel stud nurled bases. One hub rotor had the smaller stud i assume a factory replacement rotor and the other one had the larger wheel studs I assume aftermarket part rotor. Has anyone come across this and if so what part number wheel stud did you use for the larger stud
Thanks
Report this Post10-25-2020 01:36 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are converting OEM rotors to hubs, then the longer stud is Dorman PN 610-323 Qty:10
However, if you are using new aftermarket hubs, then the holes for the wheel studs are sometimes larger and you need another stud option. Here is a side by side of the stock fiero wheel stud and the one from the aftermarket hubs with the larger shank:
So if stock fiero wheel studs don't fit the hub hole, then use this part number: Dorman 610-427. It has a stepped shank and will fit the hole in the rotor while still retaining the M12-1.5 thread pitch.
Here is what these studs look like installed. Notice it has slightly more than 1 7/16" threaded length, but more importantly notice the protruding shank:
To use these wheel studs you will need to bevel or enlarge the backside of your brake rotor holes so they slide over the enlarged shank.
pmbrunelle
Total ratings: 62
Report this Post10-25-2020 02:37 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That might work for people with 5x115mm GM hubs who would wish to convert them to 5x4.5" by machining oversized stud holes, slightly offset from the existing ones.
[This message has been edited by pmbrunelle (edited 10-25-2020).]
Meatpiemonday
Report this Post10-25-2020 03:28 PM Click Here to See the Profile for MeatpiemondaySend a Private Message to MeatpiemondayEdit/Delete MessageReply w/QuoteDirect Link to This Post
Once again this website and the experts who answer questions like mine...THANK YOU! Thanks for the photos and part numbers. I will be getting those wheel studs tomorrow!
