  Groaning when turning
Groaning when turning by owenspike
Started on: 10-16-2020 02:39 AM
Replies: 2 (108 views)
Last post by: owenspike on 10-16-2020 11:52 AM
owenspike
Report this Post10-16-2020 02:39 AM Click Here to See the Profile for owenspikeSend a Private Message to owenspikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I own an 86 GT. Recently I had my tie rods and a lower ball joint replaced, yet I still have a groaning/creaking noise when I turn. I've only noticed it on left turns, but they're the only turns I have to make super sharp. What would the most likely causes be?
Report this Post10-16-2020 04:13 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you turn "at lock" or "sharp" the front spinal hit stops somewhere on the suspension and often makes noise.
Clean and Lube the contact points w/ a thin film of Brake Grease.
Front and Rear Wheel Bearing are Not preloaded and allows some minor play... If the brake's "dirt shields" are bend can hit the rotor and make noise.
Look for "wear" where the shields hit.
If the rotor as been replace, some are not made right and hat areas does same... Likely need to pull the rotor to see "wear marks" on them and shields.
owenspike
Report this Post10-16-2020 11:52 AM Click Here to See the Profile for owenspikeSend a Private Message to owenspikeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just had my bearings redone and well, but my brakes, rotor, caliper, and pads, are basically non-existent. I'll look at the shield there. Thank you!
