  Oil leaking from FRONT of car?
Oil leaking from FRONT of car? by Squall86GT
Started on: 10-15-2020 10:10 PM
Replies: 13 (367 views)
Last post by: theogre on 10-25-2020 11:02 PM
Squall86GT
Report this Post10-15-2020 10:10 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
So there’s a consistent minor leak of oil coming out of basically the middle of under the front hood. It’s slightly tan, thin cleanish oil. What is that?
wftb
Report this Post10-15-2020 10:30 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Could be fluid out of the brake master or the clutch master cylinder.
86 GT built 2.2 ecotec turbo
rear SLA suspension
QA1 coilovers on tube arms
Squall86GT
Report this Post10-15-2020 10:39 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks. I’ll check
pmbrunelle
Total ratings: 63
Report this Post10-15-2020 11:55 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only oil up front is ATF running to and from the the automatic transmission oil heat exchanger in the radiator.
montegut
Report this Post10-16-2020 12:24 AM Click Here to See the Profile for montegutSend a Private Message to montegutEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a very similar problem and it turned out to be the steering stabilizer.
Report this Post10-16-2020 04:28 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any/all Above is possible...
or something spilled or Brake Fluid got into Spare tire well and drain thru a drain hole at bottom.
RF Brake has a tube above the steering rack. If that leaks, brake can damage the aluminum rack body. (B-fluid Leaks at the wheels can do same for alloy rims.)
Brake fluid isn't just feels like oily, can/will "burn" your skin too and doesn't smell like most oils.
Total ratings: 236
Report this Post10-16-2020 07:59 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is a key indicator... if it's coming from the drain hole in the front "bucket", then it's from inside the front compartment. If it's not, then it's not.
Remove the spare tire to expose the drain hole at the lowest point of the bucket.
MulletproofMonk
Total ratings: 78
Report this Post10-16-2020 02:46 PM Click Here to See the Profile for MulletproofMonkClick Here to visit MulletproofMonk's HomePageSend a Private Message to MulletproofMonkEdit/Delete MessageReply w/QuoteDirect Link to This Post
My son's car had "brown fluid" leaking out of the front drain hole... it was rotted leaves and water...
-Brian
Removing the roof panel
My HUD install thread
Modified stock air canister and base to 3.5 inch for 3800na
Squall86GT
Report this Post10-16-2020 11:01 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found it! There was no fluid in the bucket and when I looked under the car it was obvious it was coming from the steering dampener. Thanks
Report this Post10-17-2020 01:18 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not an emergency but Get another soon.
Help to stop S-wheel slamming your hands crossing angled RR tracks etc.
[This message has been edited by theogre (edited 10-17-2020).]
Squall86GT
Report this Post10-17-2020 10:15 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will do. Thanks guys
Squall86GT
Report this Post10-25-2020 01:10 PM Click Here to See the Profile for Squall86GTSend a Private Message to Squall86GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The part is SC2943 and it’s out of stock everywhere. Is there an alternative/equal part for the steering damper?
fierosound
Total ratings: 286
Report this Post10-25-2020 03:39 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stores usually order from a warehouse that may not actually have any.
eBay may be the best bet.
Pep Boys
https://www.pepboys.com/mon...amper/product/422819
Summit
https://www.summitracing.co.../mon-sc2943/overview
In the meantime, here's the specs for the thing
http://www.monroe.com/en-US/e-catalog/SC2943/
[This message has been edited by fierosound (edited 10-25-2020).]
Report this Post10-25-2020 11:02 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ebay or RA might have it but have to watch both as one day have it next day none next day does again.
IOW RA and some others "inventory" changes every day even every hour for old parts.
