  Can the Crank Pully be removed without issue?
Can the Crank Pully be removed without issue? by BitStream
Started on: 10-14-2020 02:05 PM
Replies: 4 (288 views)
Last post by: fierosound on 10-15-2020 02:05 PM
BitStream
Report this Post10-14-2020 02:05 PM Click Here to See the Profile for BitStreamSend a Private Message to BitStreamEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I have my 1986 Fiero that has starting issues.
We have been working on it. In the process however, when changing out the battery, one of the post connectors fell into the engine compartment and somehow got in behind the crank pully between the pully and the engine block. for the life of me, I can't get the dam thing out.
I am just wondering... I have to replace the belt anyways, can I take that pully off to get the battery bolt out of there? Or am I looking at other issues.
Thanks.
Ervin
fierosound
Total ratings: 286
Report this Post10-15-2020 11:13 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shouldn't be a problem. Just 4 bolts holding the pulley on.
Spadesluck
Report this Post10-15-2020 11:40 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Crank pully aka harmonic balancer, is one big bolt and needs a pully puller. I do not think the harmonic balancer can be removed while in the car without having the cradle dip down.
BitStream,
Are you sure you are referring to the correct pulley? I may be confused on what pulley you are referring to?
Report this Post10-15-2020 01:22 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by BitStream:
So I have my 1986 Fiero...
It's important to also mention the engine you're dealing with when asking for advice. Otherwise, you may receive incorrect/irrelevant information.
fierosound
Total ratings: 286
Report this Post10-15-2020 02:05 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oops... from another thread...
I have an issue with my 1986 Fiero with a 2.5 Iron Duke.
If your crank pulley looks like this, it comes off by removing the bolts holding it to a hub (Item #85)
[This message has been edited by fierosound (edited 10-15-2020).]
