I don't view DIS as so necessary for performance, it's more to have the reliability of eliminating moving parts from the ignition system.
To avoid catching the virus, delivery drivers knock, drop the parcel, and, run. So thieves now follow UPS/FedEx trucks to pick up the parcels at the doorsteps. Gotta pick up the parcels immediately...
I looked through the expense log of my project, and here are some higher-dollar items which could be applicable to a "generic swap":
RODNEY DICKMAN
470 Rodney Dickman Idler pulley kit + shift cables
100 Rodney Dickman True cold air kit
EXHAUST
1862 Summit Racing (split over 7 separate orders) U-bends, bellows couplings, V-bands, including replacement parts for when I screwed up cutting/welding. Mostly all stainless steel.
15 Local metal shop 3/8" round rods to make hangers
42 Rockauto 6x rubber exhaust hangers
158 eBay Rod bender Huth HMRB6017
100 amazon 10 lb spool of 309LSi MIG wire
This is still a lower-end estimate on the exhaust, I'm neglecting gaskets (two sets), rivnuts, abrasives.
ENGINE WORK
680 Crower Cams Cam + spring + lifter kit
564 The Wrench Monkey Pistons, rings, cam bearings.
832 Injections & Moteurs Bourassa Engine block machining
229 Injecteur Précision Injection cleaning service; didn't save me much money versus buying six new ones, since one injector was unrepairable. I had to spend maybe $80 for the single replacement.
Rebuilding the actual engine itself cost a bunch... There was maybe another 1k or 2k there of Rockauto.
ROCKER ARM DEBACLE
232 Summit Racing Comp Cams Magnum 1.52 roller-tip rockers and some other small hardware
264 Summit Racing Comp Cams Magnum 1.52 roller-tip rockers
141 Rockauto Melling stamped rockers, 4x Wix oil filters
Comp Cams Magnum rockers suck; it took me two failed sets in a row before I clued in and got stock replacements from Melling. Also with each rocker arm failure I did extra oil changes to flush out the bits of metal, so that was more $$$.
TUNING RELATED
1393 DIYAutoTune MegaSquirt 3 ECU + harnesses
192 14point7.com Wideband oxygen sensor kit
Depending on the engine computer you choose, you may need to purchase a laptop computer (with an SSD due to mechanical shock) to tune the car...
Also tuning software.
So, to summarize the most expensive items in my case:
1. Exhaust. Reusing stock exhaust would save money, as would using mild steel parts, and avoiding the use of bellows, or V-bands.
2. Engine rebuilding.
3. Computer/tuning setup. The need for a wideband depends on your approach to tuning.
[This message has been edited by pmbrunelle (edited 10-09-2020).]
