  Way to much positive camber left rear - like +30 or more
Way to much positive camber left rear - like +30 or more by donridenour3134
Started on: 10-02-2020 03:45 PM
Replies: 4 (395 views)
Last post by: donridenour3134 on 10-17-2020 01:03 AM
donridenour3134
Report this Post10-02-2020 03:45 PM Click Here to See the Profile for donridenour3134Send a Private Message to donridenour3134Edit/Delete MessageReply w/QuoteDirect Link to This Post
85 GT rear left. My son slid the car into a curb. Broken wheel and tire was WAY toed in and WAY positive camber. I took it all apart and to my surprise couldn't find anything bent. I removed and/or checked all the following:
Control arm - not bent or twisted - checked against a good arm
Ball joint - replaced but only maybe a little bent where it mounts to the control arm
toe link - replaced but no obvious damage - this does seem to have corrected the toe in
strut - not removed but not bent and has recoil
cradle fastening points for control arm - no signs of bending or twisting
spindle - removed, no signs of bending or breaking
top strut mount - no deflection of the metal in the engine compartment, all fasteners look ok and are tight
I am totally stumped. What am I missing?
cvxjet
Report this Post10-02-2020 04:36 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
A) The camber adjustment is via the two large bolts that hold the strut to the spindle...It can be confusing to move it the right way.....
B) the other possibility is that the top part of the spindle has been bent....Take a picture of it and post it....or make a cardboard template and compare the two sides to see if that one is out of shape.
C) Tell your son not to run into curbs!
donridenour3134
Report this Post10-04-2020 01:39 AM Click Here to See the Profile for donridenour3134Send a Private Message to donridenour3134Edit/Delete MessageReply w/QuoteDirect Link to This Post
I even loosened those two bolts, put the wheel back on, and let it down hoping the weight would straighten it up. didn't help. I had already tried pushing in/down on the strut/ spindle joint while tightening them back up. Also didn't help. I'll check the spindle. I already told my son! LOL Thanks!
pmbrunelle
Total ratings: 62
Report this Post10-04-2020 12:21 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
We need photos if you want us to see something you've missed, otherwise we're grasping at straws.
donridenour3134
Report this Post10-17-2020 01:03 AM Click Here to See the Profile for donridenour3134Send a Private Message to donridenour3134Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the suggestions. I did find the strut is slightly bent so I have new ones to put on. I think I'll go ahead and get another spindle. I'm not sure it's bent but I did notice the paint has come off the area where it would have bent or at least flexed. The paint on the opposite side is fine.
Don Ridenour
85 GT 3.4
