  Duke thermostat gaskets
Duke thermostat gaskets by fierosound
Started on: 09-18-2020 11:49 AM
Replies: 22 (997 views)
Last post by: theogre on 08-17-2021 12:07 PM
fierosound
Total ratings: 286
Report this Post09-18-2020 11:49 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Starting this post because this has been an ongoing problem for years....
Most Auto Parts places sell you this gasket for the thermostat housing.
This full flange gasket is almost useless when you need the ring type.
The circled area is usual point of failure because there is barely any seal there.
The Ring type seems to no longer exist (discontinued?).
But there must be a good alternative.
The paper gasket shown is for the housing with a flat face.
[This message has been edited by fierosound (edited 07-19-2022).]
fierosound
Total ratings: 286
Report this Post09-18-2020 11:50 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Ogre from another thread...
Originally posted by theogre:
⚠️ Warning:
There are 2 T-stat housing for Fiero L4. Maybe more but Actually seen and have two types.
Simple Three hole Gasket above are for old type w/ the flange is totally flat where meets engine. This type has thin sheet metal flange w/ edges rolled 90° "up."
This Gasket Must Not be used w/ T-stat came w/ a "rubber" seal in Groove in the Flange.
Later "update" version has thick flat stamp steel flange and use the "rubber" seal. I don't know exactly what year first came w/ it but If it is in 84--- Very Likely the whole engine was replace under warranty/recall.
I don't think RA or any others have a seal for updated T-stat pipe.
Example: FEL-PRO 35342 "O-ring"
O-Ring Thickness (in) 0.1
O-Ring Outside Diameter (in) 1.725
O-Ring Inside Diameter (in) 1.5249
And maybe too thin even if others are correct.
I had to make a gasket.
Made of thick cork (⅛/0.125 inch I think. not digging it out to post now.) Permatex made for custom caskets to fill up most of the gap and coat w/ RTV and Wait a few of Days to cure completely before fill the system.
This before "glueing" both sides.
Yes, I know don't use RTV w/ nearly all gaskets. Problem is 2 fold... The Thick cork barely or don't compress and trying to fill big gap w/ RTV alone won't take 15+ PSI Coolant very long either.
Between the 2 and allowing RTV to completely cure is been 6+ Years and still seals.
RTV takes Hours to Days to cure. Curing Is Not Drying. Dry RTV w/o time to cure has cause huge problems to people using them.
[This message has been edited by fierosound (edited 09-18-2020).]
fierosound
Total ratings: 286
Report this Post09-18-2020 11:56 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Maybe this is why we can't find a gasket.
Found this online regarding this PN for the thermostat housing I found in P22 Parts Book.
The P22 Parts Book lists a seal PN 3049485 for 84-85 Duke E/Z Fill Thermostat housing.
On eBay - https://www.ebay.com/p/656503295
[This message has been edited by fierosound (edited 08-16-2021).]
edfiero
Report this Post09-18-2020 12:25 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty sure I am not using a gasket there. I used RTV if memory serves correctly.
Report this Post09-18-2020 01:28 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dug thru old pic's... (2014 when fix mine w/ DIY "gasket.")
Here are both types w/ old "rubber" on update one...
Another angle of the update one...
If you have the old style one, many have bent flanges. Likely related to long hose pulling on it, worse if you have crap dog bone and/or motor/trans mounts.
If you bend it flat, only warps again for same reasons and likely easier as bending weaken it. Above old type was warped then flatten and didn't install for this reason.
Might find gm 10038440 ACDelco 15-80794 but is whole thing and cost ~ 30 - 40 often more.
Many claim has X old part but out of stock on page or at checkout.
[This message has been edited by theogre (edited 09-18-2020).]
fierosound
Total ratings: 286
Report this Post09-18-2020 02:40 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
<deleted>
Report this Post09-18-2020 04:47 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Old style" looks like it has a groove for the O-ring seal - the part listed in P22 Book.
Felpro just decided to make a flat flange gasket.
No. The "goove" in the old style is just extra metal for a seem where tube joints to the base flange. Or seem for part holding inner tube. Don't have pic of other side area and can't find the part now.
"Paper" gasket from FelPro et al seals the whole flange area to try to eveny load on the part and bolts. Same setup used by many OEMs not just GM.
P22 and OEM often don't match what in installed at the factory.
Most people only have crappy pirate scanned copy P22 often sold as CD years ago. That 84-86 Duke Head shows # 61 T-stat Housing w/ new style PN 10038440 retain by 2 bolts and #28 "Sealant, Silicone RTV" w/o PN likely is the new "o-ring."
If GM have older version of P22 likely had 61 old T-stat pipe # and 28 w/ a gasket #. Or GM may not bother w/ a gasket like did w/ many Duke valve cover gaskets.
87-88 head list is about the same but no "extra" number from a gasket #. So I guess 87 started the new style.
Many RWD and FWD dukes old type flange w/o a problem most times. But If they have crap dog bone and/or engine/trans mounts then can have same problem.
Example: People sold me the Fiero also had FWD Olds w/ same engine had broken dog bone mount and wreck PS Pump and more. Told them to donate or junk it because can't fix damage themselves or spend a lot more money.
fierosound
Total ratings: 286
Report this Post09-18-2020 05:02 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
n/m
[This message has been edited by fierosound (edited 09-25-2020).]
fierosound
Total ratings: 286
Report this Post09-24-2020 11:39 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
<deleted>
Report this Post09-25-2020 12:12 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
So order it and try one...
This part is mail-able so for once doesn't force $8 or more shipping on part cost < $1 and weighs a few ounces max.
That if can mail to Canada...
I can't find my extra housings in spares or dead box.
[This message has been edited by theogre (edited 09-25-2020).]
fierosound
Total ratings: 286
Report this Post09-25-2020 12:15 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will be here Monday thru Amazon.ca
Didn't want to say anything further until I get it.
fierosound
Total ratings: 286
Report this Post09-28-2020 05:19 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got it today. Not suitable - more like an O-ring.
In email discussions with a Tech at Stant.
Surely some other application, be it a truck, tractor or marine uses something suitable in the size we need.
Report this Post09-30-2020 01:03 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is hard to tell from 1 iffy picture but at least doesn't cost allot.
RA said had "glue" on 1 side to stay put installing it so I thought maybe flat ring? Is it even close to fit?
fierosound
Total ratings: 286
Report this Post09-30-2020 10:55 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
<deleted>
fierosound
Total ratings: 286
Report this Post10-13-2020 03:19 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
<deleted>
Report this Post10-13-2020 08:24 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
bottom ring is likely too big to compress right. Over Compressing rubber can squeeze out, break or both. More so w/ gap isn't complete close like here.
Could do same as "my" top post above. Cheap and works.
Or Find "better then cork" and do similar. Cork composite material isn't crap that many think. Most just have no clue how to use it right.
Could find 2 or 3 small rings that nest to fit. Small as size of "rubber" like 1/8" to 3/16" to compress good. 2 or 3 different total sizes to nest w/o bothering each other.
Could search and buy new T'stat tube hopefully should come w/ the gasket. Cost $30 to $50 each. For many this is a better option because tube often have "Rust" eating thru the sides, at top making hard to seal the cap or both. One of my "spares" has holes thru the side, One use has minor top rust.
fierosound
Total ratings: 286
Report this Post02-20-2021 12:16 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Saw this in another thread for original T-stat housing with rolled edge.
May work better than FelPro 35062 gasket in that application.
Originally posted by AsaBergman:
I had this issue on the 84. Previous owner overtightened and bent the flange. I used gasket "Felpro 35562 T".
It is a hard plastic gasket with a rubber o ring. Install dry, no sealant. The bolt holes have to be elongated with a file to fit.
Never leaked a drop after two years and multiple removals. No overheating issues. If the flange on the housing is corroded you must clean it good.
This is the exact item I used: https://www.amazon.com/Fel-...asket/dp/B000C2E4GM/
[This message has been edited by fierosound (edited 02-20-2021).]
Report this Post02-20-2021 04:47 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless you mod the "gen2" housing, very likely it won't work.
MAYBE Solder flat sheet in the indent to flatten then use any old style gasket.
But is way more work the making a gasket and use some sealer as needed as said above.
AsaBergman
Report this Post02-21-2021 05:04 PM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another option is to have a machine shop mill it flush to remove the ring. The flange on this housing is much thicker than the other style housing and will still be thicker even with some milling.
AsaBergman
Report this Post02-21-2021 05:07 PM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
AsaBergman
Member since Apr 2018
Hello, that was me. That gasket won't work on this housing, I tried it as I have both t-stat housings. It only works on the other smooth housing. Unfortunately the o ring is not thick enough.
[This message has been edited by AsaBergman (edited 02-21-2021).]
Indy-453
Report this Post07-06-2021 12:20 AM Click Here to See the Profile for Indy-453Send a Private Message to Indy-453Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just wrapping my head around this thread. There are 2 types of thermostat housings.
This is an old style thermostat housing
This one IS recommended to use the traditional paper gasket (Fel Pro 35062) or try out Fel Pro 35562 as suggested by AsaBergman.
Report this Post07-08-2021 05:17 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Best way to avoid a leak is sealer
Report this Post08-17-2021 12:07 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update: As I said, Made a gasket years ago for new type "tube" w/ cork and RTV... Finally failed. The cork w/ RTV sealer never compressed the cork and sealer can't survive 15psi and fail sooner or later. Sorry, No Pics because no time to take them.
Made a new casket out of thickest Permatex "tar paper" material. This is a bit thicker then depth of wide groove where old "rubber" lived.
The new casket compresses a bit when mounted. I used High Tack sealer to hold it to the "tube." (Would like to use Super 300 or Aviation sealer but didn't have it and no car to get.)
I pressure tested w/ Stant ST270 tester (update version of st255 ACdelco etc. low clearance tester.) then drive ~ 2 hours and seem to work and w/o hours to days for RTV to setup.
I used same method to replace casket for 87+ belt tension part where mounted over unused WP hole in the block that last 15+ years.
Often will fail w/ old type "tube" and w/ or w/o paper gasket used for them.
Old "tube" flange is weak and flex enough to break the seal.
even w/o that, RTV needs perfect cleaning to "glue" the surfaces. Poor cleaning = leaks. Many times more so if whatever behind it sees > 1PSI. If a gap is > a fraction of 1mm likely will fail sealing any PSI.
RTV has a gap filler only work for things w/o pressure like timing cover to pan on Duke engines. Even then needs prefect cleaning.
[This message has been edited by theogre (edited 08-17-2021).]
