  3800sc water ports
3800sc water ports by pontiacfierokid1985
Started on: 09-15-2020 11:32 AM
Replies: 3 (105 views)
Last post by: olejoedad on 09-16-2020 07:57 AM
pontiacfierokid1985
Report this Post09-15-2020 11:32 AM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone drilled the thermostat housing on the intake to make more water ports I plan on running my inlet heater core hose here and as well going to be installing my coolant probe here for the fan adjustable fan switch controller to work. The outlet for the heater core I was going to tap the front hole where the plastic elbow would go is these 2 spots ok to use. I’m as well running the 2.8 fiero t stat housing what gasket do I use to Seal the mating surface together ?
Report this Post09-15-2020 12:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's easier and more sensible to use the port in the LIM beneath the S/C snout as the heater core feed.
The heater core return can go to the left (lower) port for the elbow.
They can both be tapped to 3"4 NPT without drilling.
pontiacfierokid1985
Report this Post09-15-2020 11:38 PM Click Here to See the Profile for pontiacfierokid1985Click Here to visit pontiacfierokid1985's HomePageSend a Private Message to pontiacfierokid1985Edit/Delete MessageReply w/QuoteDirect Link to This Post
This just clarified a bunch of headaches for me thank you very much kind sir
[This message has been edited by pontiacfierokid1985 (edited 09-15-2020).]
Report this Post09-16-2020 07:57 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to help.
