Thread Closed  Topic Closed
  Delco radio/cassette repair (with Blaupunkt cassette unit)
Post New Topic
Printable Version
This thread has been moved here: FAQs & HowTos.
Delco radio/cassette repair (with Blaupunkt cassette unit) by fierosound
Started on: 09-04-2020 06:07 PM
Replies: 10 (1446 views)
Last post by: fierosound on 09-26-2020 02:04 PM
fierosound
Total ratings: 286
Report this Post09-04-2020 06:07 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Delco UX1 radio cassette I have (Blaupunkt 4-button cassette unit) needs a new optical sensor.
When it doesn't work properly it looks like motor has stopped to the "brains" of the unit.
The unit then thinks it's reached the end of tape and reverses back and forth before ejecting tape.
The part from Blaupunkt is no longer available.
But here is a way to test and repair it.
The Blaupunkt unit schematics/wiring diagrams shown are here:
https://www.radiomuseum.org...r_23_7642888170.html
Of course, Honeywell discontinued part number HCL1395 a couple of years ago, so hard to find.
Reading through the comments under the video, it's apparent that Everlight ITR20904 also works.
https://www.alldatasheet.co...RLIGHT/ITR20904.html
I will give this repair a shot.
Ordered 5 pieces through eBay UK (cheap enough) - and coming from Hong Kong so will take a while.
https://www.ebay.co.uk/itm/333166499856
[This message has been edited by fierosound (edited 09-26-2020).]
fierosound
Total ratings: 286
Report this Post09-04-2020 06:34 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
More DIY on the cassette mechanisms.
http://www.gnttype.org/tech...ges/tape_player.html
Cassette drive belts...
GM/Delco Autosound Cassette Players 1980 thru mid-1990's made in 4 styles.
(1) Non-auto reverse models use SBX7.4
(2) Auto reverse Fijitsu 3 (Mechanical) Button Mechanisms use SBS8.6
(3) Auto reverse Blaupunkt 4-button Mechanisms use 2 belts: AV-SBS4.9 & AV-SBS9.2
(4)Pioneer (88 up) and Alpine Mechanisms (91 up) have electronic switch buttons SBS9.2
http://kenselectronics.com/lists/belts.htm#Auto
On Blaupunkt units, the Pulse Generator Disk (Delco PN 1226632) is sometimes the culprit.
https://www.ebay.com/itm/De...ng-Disc/124095797548
[This message has been edited by fierosound (edited 09-04-2020).]
fierosound
Total ratings: 286
Report this Post09-06-2020 11:57 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seller refunded $ - part not available.
Here's a Delco item that looks like it is the correct part (but shipping to Canada is ridiculous)
GM Delco 90-95 Type D 2000 Series Cassette Deck Light Sensor Assy 1229219 NIB
https://www.ebay.com/itm/GM...19-NIB-/262385753000
[This message has been edited by fierosound (edited 09-24-2020).]
donuteater306
Report this Post09-07-2020 08:18 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Not that it couldn't fail, but i've never had to replace that part. In my experience diagnosing the scenario you described, i've always found a broken drive belt. Push the tape in, the unit switches direction and ejects the tape.
fierosound
Total ratings: 286
Report this Post09-07-2020 09:47 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mine is apart and has no broken belts.
It runs perfectly fine when I shine a light on the sensor assembly.
So the IR light in the thing is shot.
[This message has been edited by fierosound (edited 09-07-2020).]
donuteater306
Report this Post09-07-2020 10:13 PM Click Here to See the Profile for donuteater306Send a Private Message to donuteater306Edit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting...good catch.
fierosound
Total ratings: 286
Report this Post09-07-2020 11:35 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did the same test as in the YouTube video posted above.
fierosound
Total ratings: 286
Report this Post09-24-2020 07:29 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Delco radio cassette fixed!
Above part is correct for our Delco radios with Blaupunkt cassette units.
New sensor is on right with "ribbon cable" instead of separate wires and is identical.
Repair was done as per video in first post.
Sensor snaps into unit exactly as it should.
Biggest part of job is removing old sensor and fishing new wires through and soldering them.
This new sensor wiring had a clip on the end that wasn't needed and was cut off.
Red-Yellow-Green
becomes
White-Yellow-White/Red stripe (new sensor)
Success! Cassette plays great!
AutoReverse, FF, REW, Eject and Power Off Eject all work properly.
Only now I discover this is one of those radios where the clock won't shut off when power is turned off (thus draining battery).
But I see some people have found a fix for that (replace transistor).
fierosound
Total ratings: 286
Report this Post09-24-2020 11:08 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Member since Nov 1999
Here's another sensor that looks correct (don't know why it's a "barrier" instead of sensor - translation?)
This has individual wires like the original I took out of my unit and would have been easier to install.
Delco Light Barrier 1226616/8 627 000 918 Radio Cassette Deck Part NOS
https://www.ebay.com/itm/De...art-NOS/124095951099
fierosound
Total ratings: 286
Report this Post09-25-2020 06:06 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
But I see some people have found a fix for that (replace transistor) .
Getting some NTE232/ECG232 transistors from
https://www.nettyelectronics.com/
Only $2.00 1st Class Mailing in Canada! He's a hobbyist.
One electronics place was US$15.85 for shipping, another wanted a US$10 fee for "paperwork" + shipping.
Here's repair directions with pictures to replace NTE232 transistor to fix "clock always on" problem.
http://garageledlights.com/.../body_radio_fix.html
fierosound
Total ratings: 286
Report this Post09-26-2020 02:04 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Delco Radio Service Manuals
(listing starts with year... 1984 etc.)
Place also has some Delco radio parts and new faceplates.
You'd have to look at the cover page of the Manuals for applications and radio Part Number you have - Pontiac P is Fiero
http://elliottscarradio.com...ll-kinds.html?page=6
Service Manual for the radio/cassette in FIRST post of this thread would be for UX1 Part Number 16050352
http://elliottscarradio.com...e-manual-p17419.html
See Radio RPO codes on fender decal and reference that to Pontiac part number.
From P22 Parts Book
1984 (radios had black faceplate and knobs)
Part number, description and RPO code
16033472 Receiver, radio w/Mono UL6
16033592 Receiver, radio w/Mono U63
16030042 Receiver, radio w/Stereo UL1
16030052 Receiver, radio w/Stereo UU7
16032452 Receiver, radio w/Stereo UU6
16034222 Receiver, radio w/Stereo UU9
1985
16035102 Receiver, radio w/Stereo UX1
16035122 Receiver, radio w/Stereo UL1 (except Seek/Scan)
16036912 Receiver, radio w/Stereo UT4
16040862 Receiver, radio w/Stereo UM6
16048312 Receiver, radio w/Stereo UM7 with Seek/Scan
1986-88
16050352 Receiver, radio w/Stereo UX1
16050362 Receiver, radio w/Stereo UT4
16041072 Speaker, front, 5-1/4" 4-ohm round subwoofer UQ6
16040752 Amplifier, low freq audio - comes with UQ6 option
This is the Service Manual for the Subwoofer Amplifier PN 16040752
http://elliottscarradio.com...-service-manual.html
Post New Topic
