  4.9 Suddenly Won't Idle. TPS Reads .392 v With Foot Off the Gas
4.9 Suddenly Won't Idle. TPS Reads .392 v With Foot Off the Gas by Warlordsix
Started on: 07-19-2020 10:30 AM
Replies: 4 (131 views)
Last post by: Warlordsix on 07-19-2020 06:23 PM
Warlordsix
Report this Post07-19-2020 10:30 AM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
On an easy drive last night the engine suddenly lost its ability to idle. Actually, it would barely idle, maybe 300 rpm, but I suspected it would die if I didn't keep my foot lightly on the pedal. Car has always previously idled well, 650-750 rpm. Put my ALDL Scan and ALDLDroid on it this am, and I'm showing .392 volts for TPS with foot off the gas. BTW, alternator voltage is showing 13.1 volts at idle...seems low. Fuel pressure is good.
Otherwise, the car runs well above idle.
Thoughts?
Thanks
Ernie
'87 Fiero 4.9 5-speed
[This message has been edited by Warlordsix (edited 07-19-2020).]
Total ratings: 328
Report this Post07-19-2020 12:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the TPC reading is 1v or below it should be within normal range. I suspect that your idle air motor may be bad. That what is what it was on my 4.9L. If you decide to replace it then use a depth gauge ruler or carefully measure the projection of the screw to make sure that the intitial adjustment is close. That will give you a good starting point or maybe be the sweet spot for a good idle.
Warlordsix
Report this Post07-19-2020 03:43 PM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Dennis. It's idling great now. I disconnected the battery for awhile, reconnected it, then started it up and shut it down a few times to go thru the idle learn process. Idles great now...just like it did before. Explanation? Dunno. Something spurious. I'll just keep my eye on it.
Thanks, again.
Ernie
Blacktree
Total ratings: 350
Report this Post07-19-2020 05:45 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The position of the throttle plate (and thus the TPS) at idle may have changed. Why? Good question. Maybe the throttle body is dirty, or is getting sticky at low throttle. Or maybe the idle screw (if it has one) backed out a bit.
In any case, the ECM expects a certain voltage range at idle (which is set during the idle re-learn). It gets confused if idle voltage is outside that range. Also FYI, if you find and fix whatever caused the problem in the first place, you'll need to do the idle re-learn again.
[This message has been edited by Blacktree (edited 07-19-2020).]
Warlordsix
Report this Post07-19-2020 06:23 PM Click Here to See the Profile for WarlordsixSend a Private Message to WarlordsixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks, Blacktree. I think you might be in the Central Florida Club, no? I am, too. Have only been to a few meetings, but will attend more frequently in the near future.
Ernie
