  What are these hoses?
What are these hoses? by Zentaury
Started on: 07-18-2020 01:35 PM
Replies: 7 (364 views)
Last post by: WalkerTexan on 08-07-2020 01:05 AM
Zentaury
Report this Post07-18-2020 01:35 PM Click Here to See the Profile for ZentaurySend a Private Message to ZentauryEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello, In my 86 GT I noticed some leaking on the ground, and the wheel liner is wet from probably from these rubber hoses near the rear left wheel, close to the brake line, and looks like they go behind or to the block.
Anyone has info about the size or specs to replace them?
(Now that I see the pictures looks like I took them all pointing to the steel that they connect)
Thanks!
[This message has been edited by Zentaury (edited 07-18-2020).]
Report this Post07-18-2020 01:40 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those are automatic transmission cooler lines. Clean the up to see where the leak is and check your transmission fluid level.
Blacktree
Total ratings: 350
Report this Post07-18-2020 06:31 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
IIRC, that's a common hose size. You should be able to get some at the local auto parts store. Hose rated for fuel and/or oil should be fine. It's also be a good idea to use fuel injection clamps, instead of worm-drive clamps. Worm-drive clamps can damage the hose. Auto parts stores should have those, too.
Report this Post07-19-2020 02:28 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Auto Trans coolant hose is Not like other hoses.
Hot AT Oils can "eat" many types even many rated as fuel types. In turn "Rotten hose" trash can plug other parts causing huge headaches.
At many places get AT oil hose as part of replacement/extra hose for "AT cooler kits."
The replace hose usually is ~ 2x amount needed to replace both Fiero hoses. Keep the extra and label it so can ID it later.
Clamps won't matter and most tighten way too much to cut into to rubber or even break the clamp.
Coolant oil flow is "waste oil" output from main pressure regulator on it's way to dump that into the oil pan.
Is why AT coolant flow have very little pressure to blow clamp joints if are parts are right parts. If has pressure above 1-3 psi, very likely cooling loop parts have big problems. Could be crush tubes to heat exchanger is blocked w/ crap.
Some people replace hose nipples w/ straight pipe/tube and doesn't have expanded spots to keep hose on.
When I see 2 clamp this is likely why I worry.
Losen clamp(s) on body side and Carefully pull hose off and look at the bumps. AT side should have same bumps on the metal.
Caution: Loop Hose has to go on right metal parts. Loop Hose is part of "Anti Drain" so TC won't drain when parked and need to be on the AT output.
TH125c out is bottom port. See my Cave, Automatic
Out on other units like 4T60 may not be same.
Loop hose should have outer hose aka "jacket hose" to protect the main hose between loop bracket and body. Just move that to new hose.
Zentaury
Report this Post07-31-2020 11:46 AM Click Here to See the Profile for ZentaurySend a Private Message to ZentauryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I removed the rear left wheel, the wheel liners (hopefully I can get a replacement of the plastic screws that holds them, because I broke 3).
Then cleaned the 2 coolant hoses, let it dry. I noticed that as you mentioned, the worm type "bites" the hose.
Next day put a piece of cardboard and turn on the car.
There is a leaking on the "loop hose". So I bought the Automatic Transmission Coolant Hose. Tonight I am going to replace it.
In the meantime, a quick inspection of the frame rails to see how much rust is there.
What do you think of this rust?
What is the best way to stop it?
Zentaury
Report this Post08-03-2020 05:27 PM Click Here to See the Profile for ZentaurySend a Private Message to ZentauryEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought 4 ft of 5/16 AT cooler hose and the worm-type clamps. Around 2ft were enough for the “loop” hose. Now that I am here I am replacing the other AT coolant hose.
Ran the car for a couple minutes. Before, it would leak right away. Now there was no leak.
Used Mobil 1 Dexron IV Automatic Transmission Fluid.
Blacktree
Total ratings: 350
Report this Post08-04-2020 08:43 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool deal.
Yeah, those worm drive clamps can really chew up a hose... especially smaller diameter ones. On bigger stuff, you can sometimes get away with a worm drive clamp, because the force is being distributed over a much larger surface.
WalkerTexan
Report this Post08-07-2020 01:05 AM Click Here to See the Profile for WalkerTexanSend a Private Message to WalkerTexanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you are changing that tire soon. Covered in dry rot! Ouch. Be safe out there
