  Neutral Safety Switch install question
Neutral Safety Switch install question by LoveBirds
Started on: 07-15-2020 04:02 AM
Replies: 1 (206 views)
Last post by: theogre on 07-15-2020 06:32 PM
LoveBirds
Report this Post07-15-2020 04:02 AM Click Here to See the Profile for LoveBirdsSend a Private Message to LoveBirdsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey all,
I installed the neutral safety switch the first time not thinking there was an actual procedure just thinking it was nuts/bolts, and connection the cable.
I since found the write-up from the Ogre Fiero cave and did that yesterday. (http://web.archive.org/web/20151002182331/http://home.comcast.net/~fierocave/nss.htm)
My question is, does the switch just operate (clockwise) in the same sequence as the shift cable? i.e. P>R>N>D>2>1?
Report this Post07-15-2020 06:32 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pretty much. Actually 3 separate switches I think...
Exact Wires connect or not depending on "gear."
2 big wires (F G) only connect in P N to allow starter to operate.
2 wire (D E) for BU light(s) power in R
2 wire (A B) for ECM in P N
(Pins)
