| quote | Originally posted by fierosound:
If ALL the lights are working except your brakes, I think you should be checking the brake switch on the pedal. Get a 12v test light and see if power is going through when pedal is pressed.
Just had the same problem and it was the brake pedal switch. If the OP checks and needs to order one there are two different versions std and one for cars with CC. Should be pretty easy to fix.
