| quote | Originally posted by dremu: BTDT. I have ideas, largely centered around convoluted complicated ways to kill the idiot who designed this convoluted complicated system.
More usefully, in my experience, even with all brand new parts, it may be that only one side wants to engage. That said, unless you're parking it with one wheel in the air, that's enough to hold the car.
If not fully engaging, you can help things along by motivating the calipers, see
http://www.gafiero.org/docs...oBrakeAdjustment.pdf
They're supposed to be self-adjusting, but aren't.
Ogre also has a bunch of stuff in his cave, see link are top of any Pennocks page.
Also see the relevant section in the FSM about adjusting until the levers just leave the caliper, then back a smidge. Takes a lot of fiddling and swearing, AMHIK. |
GM isn't only company w/ unified rears disk w/ park brake and All have problems not just "Fiero type." Many others have exposed parts that rust or freeze and worse. Plus GM Brake Recall fake the problem was owners fault and NHTSA LET THEM to get away w/ that
They made unified rears to fit
13" to 15" rims. Many to most 84 Fiero
had 13" wheels. 85+ 14" wheels was standard. 14" to 15" wheels only w/ various options for a given year. Newer cars w/ 16" rims and bigger, Many car models has disk on drum so disk is "dumb" as front w/ simple drum P-brake w/o auto adjust for that.
While Pictures in PDF are nice, method of adjustment is 100% crap. Same for Any manual adjustment including my cave and GM TSB is based on. About the only thing in the TSB is now you have some idea on pad clearance of a "working" rear caliper.
GM and some other Rear Calipers doesn't self adjust = bad pistons. Even if you adjust them still bad and will have problems again. Worse iffy piston can drag a pad causing major wear, warp rotor, boiled fluid causing no brakes on the highway and even a fire.
Any or all 3 cables can be bad and won't help you. Pull wheel cable jackets and watch ends. Crimped Ends or jacket can break causing problems to apply, release or both. Don't mean just locking ears break... the jackets break at the ends.
See my Cave,
Rear BrakesGet replacement caliper from a local store or online w/ local store to return core or warranty them. AZ, Advance Auto, etc. Some replacement parts of any kind are bad out of box or need the warranty soon.
