  F23 trans swap?
F23 trans swap? by fierogt28
Started on: 06-30-2020 12:29 AM
Replies: 16 (658 views)
Last post by: Raydar on 07-10-2020 01:56 PM
fierogt28
Report this Post06-30-2020 12:29 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Those that are installing F23 trans swaps, are you choosing the 3.84 ratio unit?
fierogt28
88 GT, Loaded, 5-speed.
ericjon262
Report this Post06-30-2020 01:01 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
you have ti with the metric bell housing, unless you're like me and a handful of others who swapped the metric bell onto the ecotec 3.63 gearset case.
cognita semper
https://joj2020.com/ <--- She isn't a sexual predator.
Total ratings: 236
Report this Post07-02-2020 09:36 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The "metric" bellhousing F23 has a 3.94 ratio.
The Ecotec trans that followed has a 3.82 ratio.
The early Cobalt XFE transmission has a 3.73ish ratio.
The late Cobalt XFE trans has a 3.63 ratio.
Whether you keep the 3.94 or not would be a matter of preference for how you drive and your engine's powerband and torque delivery.
fierogt28
Report this Post07-07-2020 10:48 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
If we are talking about a 3800 S/C swap...ideal trans ratio would be? (most common)
fierogt28
pmbrunelle
Total ratings: 63
Report this Post07-07-2020 11:29 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's like asking the forum what clothes you should wear, what food you should eat, or what car you should drive.
Personal preference.
Edit to add a slightly less cryptic answer:
Use what you have now (2.8/Getrag) in conjunction with your imagination to help you pick ratios.
If you had the Getrag you have now, would you like the same gearing but with an engine having 70% more torque?
Are you happy with 1st gear today? How about with more torque?
Are you happy with 2nd gear today? How about with more torque?
Are you happy with 3rd gear today? How about with more torque?
Are you happy with 4th gear today? How about with more torque?
Are you happy with 5th gear today? How about with more torque?
If you like the existing gearing, keep the Getrag (possibly with a rebuild), or get something with similar ratios.
If you don't think you like your current gearing, then imagine if you would like each gear(1-2-3-4-5-(6)) to be shorter or taller. Then, find the gearbox that most closely matches your desires.
[This message has been edited by pmbrunelle (edited 07-07-2020).]
cam-a-lot
Total ratings: 97
Report this Post07-08-2020 07:36 AM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had an F23 with the 3.94 ratio and 3800 SC motor. Loved the tranny, hated the gearing. For that engine, I found the shifts to be far too short.
I like the stock Getrag gearing with the 3800 SC much more, but am concerned about the longevity and availability of parts for the 30+ year old Getrag, so if I do go ahead with an F23, I will be going with the 3.63 gear set.
La fiera
Report this Post07-08-2020 10:58 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Metric 3.94 and it fits my engine's powerband very well, I'm very happy with it.
fierogt28
Report this Post07-08-2020 11:18 PM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was more concerned about the 3800 S/C project on how it would hold up with the F23 trans.
Since there is more replacement parts for the F23 out there than the stock getrag, its just an option.
Some people on the net have 6-10 or a batch of F23s for sale, just checking in to see what best option is best.
fierogt28
pmbrunelle
Total ratings: 63
Report this Post07-09-2020 12:04 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
As a general rule, taller gear ratios are better for transmission durability.
But considering that Justinbart made it into the ten-second club (quarter mile) with an F23 transmission, I think that a stock or lightly modified 3800SC should be no problem, regardless of the ratios.
I would pick the ratios based on the best feeling for the driving experience.
fierosound
Total ratings: 286
Report this Post07-09-2020 01:38 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Agreed.
But hard to do unless you can drive a buddy's car with same engine/transmission you are considering.
It's a real pain in the butt if you "guess wrong".
Total ratings: 236
Report this Post07-09-2020 02:22 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Didn't he have the 3.63 final?
Total ratings: 236
Report this Post07-09-2020 02:23 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
My current 282 has the 2.19 second and 1.02 fourth. I've building a 3.94 box for it. Judging by how much the 1.02 fourth wakes it up compared to the 0.94 fourth, the 3.94 final is going to rip.
Report this Post07-09-2020 06:26 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes.
He also had the transmission out of the car for work/repairs a bunch of times.
Total ratings: 236
Report this Post07-09-2020 06:32 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Including breaking the left bearing boss right off the diff carrier... which is an impressive testimony to the strength of the case.
pmbrunelle
Total ratings: 63
Report this Post07-09-2020 07:31 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought that most of Justin's failures were 282 or Muncie related.
ericjon262
Report this Post07-10-2020 02:07 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
he had an F23 failure, but it was related to the work he performed, IIRC, he installed an oil slinger wrong and messed up the bearings.
cognita semper
Total ratings: 463
Report this Post07-10-2020 01:56 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
THIS LINK CONTAINS MALWARE. I had to shut down my computer to get my Antivirus to stop freaking out.
