  CV AXLE REPLACEMENT?
CV AXLE REPLACEMENT? by RPYRAZOO
Started on: 06-29-2020 09:52 AM
Replies: 2 (118 views)
Last post by: AsaBergman on 06-29-2020 12:23 PM
RPYRAZOO
Report this Post06-29-2020 09:52 AM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are all '87 GT cv replacement axles the same, if not which is the best pic ?
Report this Post06-29-2020 11:15 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
brand may not matter...
make sure axle length is right.
Put both on a bench and Compress the inner CV.
See my Cave, Axle
While has a list for length. Check them side by side is best.
Even then Do Not give or return the core until the job is done and tested. Many "rebuild" axles have problems right out of the box.
AsaBergman
Report this Post06-29-2020 12:23 PM Click Here to See the Profile for AsaBergmanSend a Private Message to AsaBergmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I doubt there's much difference in quality between the axles available for the Fiero. I picked up a Duralast manual transmission axle at Autozone and it's been fine. Lifetime warranty. Probably 8k miles on it so far. This same axle is on Rockauto as being Suntrack / Trakmotive.
Edit: I did compare the Autozone axle side by side compressed with the original OEM axle. They were the same length.
[This message has been edited by AsaBergman (edited 06-29-2020).]
